  #41 (permalink)
Old November 1, 2009, 10:16 PM
bojangles's Avatar
Asus P5K Deluxe Mainboard Review (page 5) - X-bit labs
Take a look at the Northbridge Configuration link in the Advanced tab in your BIOS. There should be something there to set up your second PCI-E slot properly.
EDIT: Please let us know what each of these settings does (what it says in BIOS).
  #42 (permalink)
Old November 3, 2009, 09:43 AM
Randyman's Avatar
I have it set as follows:
Memory re-map ( enabled)
Initiate Graphic Adapter (peg/pci)
Peg port control (Auto)
peg prt force x1 (disabled)
C.G.I. Function (enabled)
Just my opinion but you would think they would have some way of you seeing the second slot in the bios and it's current status.
Everything is enable,disable or auto. Which is fine for most things in the bios.
  #43 (permalink)
Old November 3, 2009, 09:47 AM
bojangles's Avatar
Turn on the ASUS CGI Function.
Could you post pictures of the submenus for each of those options?
  #44 (permalink)
Old November 3, 2009, 10:02 AM
Randyman's Avatar
I will try let me get on the other machine.
Oh that picture is not my BIOS settings.
I was just using it as reference so you could see what the default settings are and my settings which are posted below the picture.
  #45 (permalink)
Old November 3, 2009, 10:22 AM
Randyman's Avatar
  #46 (permalink)
Old November 3, 2009, 04:29 PM
Randyman's Avatar
Ok after much frigging around I found the problem. I hooked up a speaker to my system board and then installed a gpu in the second slot. I then hooked up the monitor to it and fired up the machine.
I got one long beep followed by 3 shot ones.
All this work because I didn't have a motherboard speaker hooked up. Never again.
I appologise to all you guys that spent so much time helping me.
The board has a light that is supposed to come on if there is a problem.
  #47 (permalink)
Old November 3, 2009, 05:20 PM
3.0charlie's Avatar
Actually the speaker has nothing to do with your solution. But connecting a monitor to the second card, yes... now run 3Dmark again after enabling Crossfire and compare results.
Hydro-Quebec is salivating...
  #48 (permalink)
Old November 3, 2009, 05:36 PM
Randyman's Avatar
well the error codes must mean something. The monitor will not work in the second card on the bottom. Only the top.
  #49 (permalink)
Old November 3, 2009, 05:39 PM
bojangles's Avatar
Are there red lights shining on the back of the graphics card? usually that means it's not getting enough power or there is a fault or ground somewhere.
  #50 (permalink)
Old November 3, 2009, 05:56 PM
Randyman's Avatar
nope not any lights.
One thing I did do was move my network card down to the slot to see if it would work and it did.
So bothe vid cards only work in the top slot.
WTB: 2900 XT stock cooler alexgheseger Buy/Sell & Trade 6 January 29, 2008 04:12 PM
2900 PRO or 8800 GTS ? thekillerjud Video Cards 14 October 18, 2007 05:59 PM
NordicHardware on ATI Radeon HD 2900 XT CrossFire overclocking Supergrover Reviews & Articles from the Web 0 May 30, 2007 05:09 PM
ATI Radeon HD 2900 XT benchmarks Babrbarossa Reviews & Articles from the Web 6 April 24, 2007 07:51 AM
X1600 Pro Crossfire or Single X1650 XT? BALISTX Video Cards 8 April 4, 2007 11:09 AM
