Old October 23, 2009, 04:27 PM
MarkOne's Avatar
Default T-Rad2 GTX the Best move I ever made
I just install my new Thermalright T-Rad2 on one of my radeon 4890,,,, WOW.....33'C on idle and 53'C on the crysis GPU test...... and no noise.... I also install the VRM rad the one with the rad horizontal. The other best thing I did is to remove the parts from my twelve hundred and place them in a Squeleton.... The NB drop 5'c ... So for me finish the stock cooler on GPU, I do not overclock my CPU , but my next build will have a WC just for the water block of the GPU, when you taste the silence , you want more...
Old October 23, 2009, 05:02 PM
Perineum's Avatar
Hmm, viral advertising?
Hrmm, maybe not. Other posts look alright.
To the original poster: why not include some pictures of your setup, or at least a link to the product?
Old October 23, 2009, 05:14 PM
What fans did you strap onto it?
Old October 23, 2009, 05:53 PM
BrokenHalo83's Avatar
The T-Rad2 GTX comes wth 2 92mm fans. they do a decent job and are pretty quiet. I've got one on my 4870 and it stays pretty cool. You can actually touch the back of the card with out burning your darn hand
Old October 23, 2009, 06:21 PM
Sushi Warrior's Avatar
Does it work on GTX260's?
Old October 23, 2009, 06:27 PM
or gtx 275's ?
Back up - Ebay (Inik1) or Heatware
only the 55nm 260's. 65nm use the HR03. it is compatible with 275's. Compatibility list
Old October 23, 2009, 06:36 PM
Look what I found : Xigmatek's new Bifrost VD1065 VGA Cooler spotted :: TweakTown
Old October 23, 2009, 06:42 PM
Hardware Canucks Reviewer
Originally Posted by Inik View Post
That looks mean... but it doesn't support the ATI 4890. What were they thinking?
Old October 23, 2009, 07:08 PM
Sweet! Even better!
Is it worth the move to I7? quikgp CPU's and Motherboards 31 May 14, 2009 04:31 PM
Move RAID 0 array to new Mobo? Squeetard Storage 1 January 31, 2009 09:33 PM
Cheapest way to move interprovincially? vulcan500rider Off Topic 11 October 5, 2008 10:41 AM
ThermalRight T-Rad2 Eagle Eye Air Cooling 3 June 26, 2008 09:24 AM
which one, and can i move it ? Unklmo Troubleshooting 4 June 30, 2007 07:23 PM
