  #21 (permalink)
Old November 23, 2009, 09:52 AM
Dr_BenD_over's Avatar
Fallen Folder
I'm guessing you wouldn't have to go through the trouble of finding an active DP adapter if you got monitors that had native support for it, for example the NCIX.com - Buy NEC Multisync EA231WMI-BK 23IN IPs Widescreen LCD Monitor 1920X1080 14MS 1000:1 VGA DVI DP Pivot HAS - EA231WMI-BK In Canada. ?
All's well that's Haswell
  #22 (permalink)
Old November 23, 2009, 09:59 AM
CMetaphor's Avatar
Quadfather
That's correct. No Active DP adapter is needed if you use a native DP panel. 14ms reponse time on that one tho = ghosting
  #23 (permalink)
Old November 23, 2009, 10:17 AM
Fallen Folder
The only one I saw on NCIX... Looks like Dell may have some good ones.
  #24 (permalink)
Old November 23, 2009, 10:22 AM
Deviant's Avatar
Not noticeable enough, otherwise everyone would've complained about Dell's 2007WFP with a 16ms response time. Some will always claim that they can see "so MUCH" lag though, they're "special" and more "elite" than I can ever behold. Original IPS variants > e-IPS > TN/PVA anyday for me.
  #25 (permalink)
Old November 23, 2009, 02:21 PM
dadzilla's Avatar
So what happens if you mix your monitors a little - I have a 22 inch Dell and a 22 inch Sammy - both at the same res. I was kinda thinking longer term I would get another Dell to match up that end and then just use the Sammy - not ideal, but I can't really justify two new monitors....
I build, I game, I upgrade. I build, I game, I upgrade. I build.....
  #26 (permalink)
Old November 26, 2009, 01:29 PM
Fallen Folder
Is there an idiots guide for setting Eyefinity up? I thought I set everything up right with the display group, it looked right at the desktop, but when I launched a 3D app, it just went to clone mode on the displays. I tried fiddling with things a bit more after that but there seems to be something really screwy with the Vista 9.11 drivers and both displays wound up becoming inactive forcing me to use the little button. Note I am not using matched displays, ones a 24" and the other ones a 19" (just experimenting without blowing cash at the moment)
  #27 (permalink)
Old November 26, 2009, 01:32 PM
CMetaphor's Avatar
Quadfather
In the game did you select a surround-wide resolution? If the game defaults to a res. that one monitor can handle, then the others will either turn off or clone.
  #28 (permalink)
Old November 26, 2009, 04:49 PM
Fallen Folder
I didn't wait long enough to try, when I saw it clone I just exited to tinker more. I'll have to give it another shot when I have the time.
Eyefinity - using different monitors James_8970 Video Cards 12 February 17, 2011 05:16 PM
Eyefinity Clarification Thread Q&A CMetaphor Video Cards 62 November 4, 2010 07:13 PM
Got my Eyefinity going on!!! ontariotl Video Cards 68 October 17, 2010 03:17 PM
Jump to Eyefinity or not? CMetaphor Video Cards 38 October 9, 2009 04:17 PM
Constructive Antec 900 ideas donimo Cases 9 January 4, 2008 04:36 PM
