  #31 (permalink)
Old November 30, 2009, 08:11 PM
dadzilla's Avatar
Ouch. I just picked up a second Sammy 22 incher, hoping that I would use the two sammys with my 22 Dell. Now it looks like i need a third Sammy? This is getting expensive!
I build, I game, I upgrade. I build, I game, I upgrade. I build.....
  #32 (permalink)
Old December 6, 2009, 03:09 PM
I have ordered a 5870. I guess I didn't read up on it as much as I should have. I have three monitors but they aren't the same size and none have a displayport. I came across this forum looking for information. Shortly after I found this video on youtube.
It's called SAPPHIRE ATI Eyefinity set up with Bill Donnelly. He is the Sapphire Global PR Director.
Since I have 2 monitors that are 22" and the adapters are $100 my plan right now is just to get another 22" monitor that has a displayport. So far I have found one for $200. I have to get a new 22" monitor anyway since one of my 3 is a 19".
I'm looking forward to it considering I'm moving from a 8800gt.
Good luck to everyone.
  #33 (permalink)
Old December 6, 2009, 03:10 PM
I couldn't post the link in my last post due to forum rules.
Here it is.
  #34 (permalink)
Old December 11, 2009, 10:10 AM
What about connecting a third Monitor directly to Displayport ?
Would I still need an adapter ?
I know you mentioned that it would be bette to have three Monitors of the same Type, but I was wondering if this combination would work without an adapter at all, since Lennovo started to sell a 22" with Displayport.
  #35 (permalink)
Old December 11, 2009, 11:04 AM
CMetaphor's Avatar
Having a monitor running native displayport is the best option. And having a three of a monitor with DP will probably look the best as well.
  #36 (permalink)
Old December 11, 2009, 01:47 PM
Has anyone confirmed that you need three matched monitors? I'm wondering if two 22" monitors would work with a 24" that has 1:1 scaling modes, like my BenQ FP241W.
  #37 (permalink)
Old December 11, 2009, 01:53 PM
CMetaphor's Avatar
Doesnt have to be matched... has to use matching resolutions. your combination may, in fact, work!
  #38 (permalink)
Old December 11, 2009, 07:52 PM
Just to make it absolutly clear:
you can connect three monitors directly to a 5770, 5850 or 5870 if one of the connected monitors has a display port and you would need no additional adapter ?!
If so, then I would suggest that anyone, who plans on going this way, to take a look at Lenovos Thinkvision L2251p.
It has "only" 1680x1050, but you won't find another new monitor with a displayport at that price !
  #39 (permalink)
Old December 13, 2009, 05:17 PM
I needed a monitor with a DisplayPort. I looked around and bought a Dell P2210. They go for around $200. Good reviews, not great, but good. I found one on ebay and picked it up for $140. which is only a little more then one of those adapters from Apple.
  #40 (permalink)
Old December 13, 2009, 05:20 PM
I found another video review that I liked about eyefinity. It's the most in-depth video I've seen so far. It lasts 30 minutes. If you're interested in it you really should check it out.
AMD's ATI Eyefinity Technology Review - AMD's ATI Eyefinity Technology Review | [H]ard|OCP
Comment Thread for The Future of Stereo 3D Part 1 &2 SKYMTL Display Units 45 October 23, 2009 07:01 AM
Jump to Eyefinity or not? CMetaphor Video Cards 38 October 9, 2009 05:17 PM
HWC lan party [Games&Benchmark list] &RSVP Thread Cowboy Off Topic 6 August 10, 2009 03:56 PM
AM2+ versus AM3 Motherboards and CPUs, clarification needed superj CPU's and Motherboards 17 February 25, 2009 09:48 AM
HD4870 & HD4850 Crossfire Review Comment Thread SKYMTL Video Cards 56 August 12, 2008 06:40 AM
