View Poll Results: Eyefinity: What would you do?
Stay with Nvidia/Matrox, and wait for an inevitable response from one/both of them 9 19.57%
Switch to ATI and give Eyefinity a whirl 29 63.04%
Be happy with what I have, downgrade OS to XP/Vista 4 8.70%
Can't Decide 4 8.70%
Voters: 46. You may not vote on this poll
  #31 (permalink)
Old September 30, 2009, 08:48 AM
vintank's Avatar
Originally Posted by MacJunky View Post
It is supposed to replace DVI or something.. Have you not heard? Steve Jobs has been ejaculating mini-display ports all over the products that he forces out his tight little ass for a while now.
lol nice MacJunky just saw a review about the eyefinity and well AMD is working on an adapter that will work to run 3 x dvi so you won't need a display port monitor sometime in the future, as they have it working on 3 x dvi with a beta adapter.
EVGA X58 Classified 3 SLI / i7 920 D0 / Corsair XMS3 DDR3-1600 2gb x 6 / Noctua NH-D14 / eVGA GTX 680 / Corsair Obsidian 800D / Be Quiet Dark Power Pro 850w
  #32 (permalink)
Old September 30, 2009, 08:50 AM
gingerbee's Avatar
let me know what setup you go with. just still trying to get a confirm on dvi adapters + displayport works or not think it should
  #33 (permalink)
Old October 1, 2009, 06:58 AM
Restricted Poster
I use Eye Infinity with three WUXGA monitors. That's 5760x1200 pixels, it's the best thing I have done for gaming in years! The 5870 has no problem driving those pixels on my computer. I am very happy with it although I do think the drivers need to mature. For instance there is no bevel management, and there is no ability to open a window fullsize on just one monitor, instead it spreads across all three. I say go for it, I am not looking back. Surround gaming is where it's at.
Dan
  #34 (permalink)
Old October 1, 2009, 07:12 AM
CMetaphor's Avatar
Quadfather
Hi Dan, and welcome to the forums!
What connection types are you using with the monitors? Do you happen to be using an active DP - DVI adapter that works? Thats the real thing holding me (and many others) back from jumping into the Eyefinity game.
  #35 (permalink)
Old October 1, 2009, 08:57 AM
3.0charlie's Avatar
Hold on. Why do you need an adaptor for the 5870? The card has dual DVIs and dual HDMI ports; the Display Port is only on the 5870X2, me thinks.
edit: my mistake, DP and HDMI, not dual HDMIs.
Hydro-Quebec is salivating...
  #36 (permalink)
Old October 1, 2009, 09:14 AM
CMetaphor's Avatar
Quadfather
And for ANY Eyefinity configuration, you have to use the displayport + 2 others (dvi/dvi or dvi/hdmi).
  #37 (permalink)
Old October 1, 2009, 09:33 AM
vintank's Avatar
Dan
welcome to the forums Dan and whats the full model number of your monitors and as another person asked, do you have an active dp to dvi adapter working?
I have read around that the one from dell works but its $100, which isn't bad it does save money on actually buying 3 monitors that have display port (just so all 3 monitors match) which would be $2000 or just buying two more of the 24" Samsung I have and the adapter which would be $700 roughly.
  #38 (permalink)
Old October 1, 2009, 08:33 PM
Restricted Poster
Hi, I am using Dell 2408WFP monitors. They have pretty much every connector you could ever need on the back! I use one DP and two DVI cables for the connections.
I was going to try CRYSIS but I had that stupid "mouse" bug in the menus so I just became frustrated and uninstalled it. I mainly play ROF, details maxxed, 5760x1200 resolution. Not a single hiccup.
Dan
  #39 (permalink)
Old October 9, 2009, 04:17 PM
I haven't even installed my 5870 I bought the other day. I need to remove the watercooled 4870x2 in which I will sell off soon.
Reading all this Eyefinity stuff made me make the plunge. I have 23" LG monitors on the way as well as a buddy who is ordering me the active DP to DVI adaptor mentioned on a few forums that work well.
I hope its worth going from 32" back down to 3 23" monitors.
Intel i7 5960x @ 4.5Mhz | MSI X99S Gaming 9 ACK
32Gb G.Skill Trident RGB @3000Mhz | Asus STX audio
Gigabyte RX Vega 64 | Samsung CF791 Ultrawide 1440p (main) Yamakasi Q270 Catleap 2b @1440p (secondary)
Samsung 950 Pro m.2 @ Gen3 x4 32Gbps | Seagate 4Tb with 256 SSD cache | Corsair Obsidian 800D | Seasonic X-1250
HeatKiller 3.0 | EK RX Vega WB | TFC Exchanger Quad Rad |Thermochill PA120.3 rad|TFC Dual rad | Scythe Gentle Typhoon (x9) |Swiftech MCP655 (x2) | Koolance bay Resevior
Going to jump in: i7 upgrade suggestions appreciated chrisk New Builds 90 November 30, 2009 04:20 PM
Should I jump to i7? GT_Forthelulz New Builds 12 August 7, 2009 10:31 PM
(almost) Ready to jump in! 3.0charlie HardwareCanucks F@H Team 3 May 26, 2007 08:17 PM
