Old September 25, 2009, 11:45 AM
Default New to CrossfireX could use some help....
Hi everyone been busy lately, but I do have a quick question. I recently bought a second 4890 and I have them setup with the crossfire bridge and all that but how do I tell if they are actually running in crossfire mode? I am more familiar with SLI so I don't know that much about crossfire. Thanks
Old September 25, 2009, 11:56 AM
bojangles's Avatar
ATI RADEON HD 4890 Crossfire Video Card Setup - PCShopTalk Forum
CrossfireX should be in Catalyst Control Centre menu. There should be an enable button. Then you're good to go.
Old September 25, 2009, 12:43 PM
Oversized Rooster's Avatar
The cards need to be connected using ONE bridge. You don't need TWO bridges.
If you want to run 2 monitors, plug them BOTH into the top card and leave the bottom one without anything plugged in.
Make sure the CrossfireX checkmark in the CCC is checked.
Machine: Intel 6800K | Asus X99-E | 32GB Corsair DDR4-2666 | 500GB Samsung 960 EVO NVMe | 6TB WD Black | 2 x 4TB Hitachi 7K4000 | Corsair 750D | Seasonic XP-860 Platinum | 4GB GTX 970 G1 Windforce | 2 x 27" Samsung S27D390HS PLS | Win10 Pro 64-bit
Old September 25, 2009, 02:31 PM
Thanks for the help does it mater which "pin" the crossfire bridge is connected to?
Old September 25, 2009, 03:18 PM
Dr_BenD_over's Avatar
Fallen Folder
Nope
/filler
All's well that's Haswell
Core i7 CrossfireX/SLI tests miggs78 Video Cards 12 November 4, 2008 08:00 AM
Minimum Watts for CrossFireX e_1337 Power Supplies 10 March 22, 2008 10:59 AM
CrossfireX delay & DX10 a Lame Duck ?! way Rumor Mill 26 February 4, 2008 02:22 PM
