  #31 (permalink)
Old September 25, 2009, 10:44 PM
Thanks
  #32 (permalink)
Old September 26, 2009, 06:10 AM
will a 5870 fit in a HAF922? and when is coming the 5850?
  #33 (permalink)
Old September 27, 2009, 07:54 AM
Most decent PC cases will have a FAQ or a spec sheet that shows the length of the clearance that accomodates the video card.
For example, my CM 690 -- CM 690 - Cooler Master
It shows that 314.9 mm max card length.
So, yeah. Check the websites and you can often find the information.
Two things to remember however that will affect your clearance:
1- direction of your Hard Drive tray and therfore the connectors can be an issue.
2- position of the 6-pin / 8-pin connectors on the card can be an issue if they are in the back of the card (like the 5850 will be) as opposed to the side like the 5870.
Cheers!
Feeling_Helpful_Canuck :)
  #34 (permalink)
Old September 27, 2009, 10:11 AM
I had to cut out a slice of my hard-drive tray from my Antec Solo to accommodate my GTX 260 216SP. Fortunately, I cut extra deep, so I think the extra 0.6" won't be a problem on the HD5870.
ATI Radeon HD 5870 Pictured and Detailed FiXT Press Releases & Tech News 75 September 14, 2009 10:08 PM
24 ATI Radeon PCI-E Video Cards Benchmarked by Legit Reviews Babrbarossa Reviews & Articles from the Web 9 March 30, 2007 05:12 AM
