Old August 21, 2007, 03:45 AM
Default 163.44 BETA official (from nvidia)
right on their page. the vista's, xp's and 2000 are supported. geforce 6,7 and 8 series.
3800X2@2.2GHz--2gb PC3200--200Gb Maxtor SATA2--eVga 8800GTS 320mb--eVga nForce4 SLI mobo--Klipsch 4.1--Antec nine hundred case w/Vantec 120mm on side--Vista Premium 64bit
Join our Folding@Home team!
Old August 21, 2007, 07:38 AM
JD JD is offline
This is mainly for Bioshock. So if you plan to play Bioshock, get these drivers.
Old August 21, 2007, 01:22 PM
magictorch's Avatar
Default works very well thanks!
my 939 coal fired computer likes these...but i cant get a temp reading without loading ntunes which i dont want.
Old August 21, 2007, 01:40 PM
rivatuner :P
Old August 21, 2007, 01:45 PM
magictorch's Avatar
Default rivatuner it is then
ill reload it, forgot it had a temp readout...bumped my core up 20mhz to 585, no luck with the memory
Old August 21, 2007, 01:58 PM
my 7600 gs has a stock of 420/220 or so and I can get the clock over 600 but can't get the memory over 288 :(
Old August 21, 2007, 02:00 PM
magictorch's Avatar
Default oh thats so unfair!
mmm... I wonder what im doing wrong. I hear the 7950GTs are rotten at ocing anyway..well if you dont have an evga 7950 superclocked at 650core
Old August 22, 2007, 04:06 AM
I haven't looked for changes yet....maybe tonight....but i'm sure there's other fixes in there other than support for bioshock.
BETA's sometimes are good. (this one wasn't at 1st) nVidia in the last couple releases added a "removal" function to the driver install process eliminating the need for apps like driver cleaner and such, thing is in this release i think it's broke (or i got a corrupted download 1st time). during install i got a BSOD and that's a rare find in XP/Vista land. I rebooted and manually removed the old driver/ re downloaded the file and ran the setup. All's good so far.
Old August 22, 2007, 06:25 AM
I installed these drivers the other night, they give a bit of a FPS boost to Bioshock, nothing else though from what I can tell.
If you haven't played the Bioshock demo though, I highly recommend you do!
Q6600@3.2ghz
Asus P5N32-E Sli
4gb OCZ Platinum DDR2 @1100mhz
Antec P180
BFG GTX 260 Core 216
Corsair HX-620
Thermaltake Power Express 250W
Raptor150, WD 500gb. WD 300GB
X-Fi Extreme Music
9800gx2 Official Leaks At Cebit08!! vertex112 Press Releases & Tech News 13 March 10, 2008 06:13 PM
Official Sandra CPU Arithmetic Top 15 Supergrover Overclocking, Tweaking and Benchmarking 124 November 17, 2007 09:14 PM
Nvidia 162.15 beta drivers out ragenrok Video Cards 4 July 5, 2007 03:58 AM
Official Sandra CPU Multi-Media Top 15 Supergrover Overclocking, Tweaking and Benchmarking 13 March 11, 2007 10:30 PM
ASUS official partner for 4x4 motherboards UNESCO CPU's and Motherboards 3 November 23, 2006 10:53 PM
