Old September 4, 2009, 06:13 PM
Default What graphics cards can run Age of Conan maxed?
I'd like to buy a graphics card that can run age of conan with all setting maxed but not 2 cards in sli or a dual gpu card. I'd also like to know what power supply would handle the card in SLI if you know. The reason for this is that I'll use another card in SLI when it stops being able to run new games decently. According to the article on this site a 9800 gtx can run it on high but not max so unless something changed and made that possible I'm crossing that out as a choice. I want an Nvidia card but I have no preference over the brand (ie : Evga or xfx) thanks in advance.
Old September 4, 2009, 06:17 PM
SugarJ's Avatar
What resolution monitor are you using? And I'd recommend a GTX275 card, will handle anything on a 22" monitor. As for a PSU, 500w should be fine for a single GPU system.
Old September 4, 2009, 06:25 PM
shayan288's Avatar
+1 for sugarJ's suggestion. gtx275 is the way to go. I would go EVGA, JMO. But I would pick up a corsair tx750watt so that in the future you can get another 275 and SLI.
The 288
Q9550 E0 stepping @ 4Ghz
Gigabyte EP45 UD3P
G.Skill pc2 8500 1066mhz RAM
Western Digital 250gb
Antec 1200
XFX HD5970
Steelseries Xai Laser Mouse
Windows 7 Ultimate x64
I'm using a 26" LCD wide-screen television and have basically no knowledge of resolutions other than 800x600 in the games I play on the computer I'm using now. But in any case the aspect ratio I'm using is 16:9 if that helps at all. I'm going to go read a couple of articles on it so if I don't reply that's why.
Old September 4, 2009, 06:33 PM
Ok from what I've read in about 5 minutes I think tv's can only go up to a resolution of 640x480 which is pretty bad as far as I know. I know this is a bit off topic but I'd rather just ask here than make a new thread so any monitor suggestions to go with that gtx 275.
Old September 4, 2009, 06:35 PM
shayan288's Avatar
your using 800x600 on a 26 inch LCD monitor!?!?!? WHAT!? if you are, then I think you should ibe using 1920x1200 IIRC. a gtx275 should still run fine on your monitor, but you COULD get a gtx285 if money isnt a problem just because they run cooler, overclock better, and run quieter than a gtx275. But remember that if you get the gtx275, get it as an EVGA card because if you dont seem to be satisfied with the performance you can step up to a gtx 285 or something else because of their kickass 90 step up feature.
EDIT: ohhh, television, read it wrong. Still, if its LCD it should at least be ****x720...
The 288
Gigabyte EP45 UD3P
Antec 1200
XFX HD5970
Old September 4, 2009, 06:38 PM
So would the GTX 275 be able to max it on a monitor with a recommended resolution of 1680x1050 or would I need a better graphics card for that? Also for a bit of something to go on in terms of how hard it is to run it has a lot of specs similar to crysis and some are even a bit higher I think.
Old September 4, 2009, 06:45 PM
SugarJ's Avatar
Why don't you post your specs, and what budget you are looking at spending? Then we can offer specifics. But if you're going to run at 800x600, a 9800gt would do it no problem.
Old September 4, 2009, 06:49 PM
Ok specs up to this point are
NCIX.com - Buy Antec Nine Hundred Mid Tower Gamer Case 900 ATX 9 Drive Bay No PS Top USB2.0 1394 Audio - NINE HUNDRED In Canada.
NCIX.com - Buy Western Digital Caviar Black 640GB 7200RPM 32MB Dual Proc 3.5IN SATA Hard Drive OEM 5YR Mfg Warranty - WD6401AALS In Canada.
NCIX.com - Buy LG GH22NP20 Black DVD+RW 22X8X16 DVD-RW 22X6X16 DL 16X/12X 2MB IDE OEM - GH22NP20 (BLACK) In Canada.
NCIX.com - Buy Logitech Classic Keyboard 200 Spill Resistant USB Black Keyboard - 968019-0403 In Canada.
NCIX.com - Buy Gigabyte GN-WP01GS(1.0) Wireless 802.11B/G PCI Adapter 54MBPS Software Access Point Smart SETUP3 - GN-WP01GS In Canada.
NCIX.com - Buy Microsoft Windows Vista Home Premium 64BIT OEM DVD with Windows 7 Upgrade Offer - 66I-03525 In Canada.
NCIX.com - Buy Gigabyte EX58-UD3R ATX LGA1366 X58 DDR3 2PCI-E 2PCI SATA2 RAID Sound GLAN CrossFireX Motherboard - GA-EX58-UD3R In Canada.
NCIX.com - Buy Logitech MX518 Gaming Grade Optical Mouse 1600DPI USB SILVER-BLACK - 931352-0215 In Canada.
NCIX.com - Buy Intel Core i7 920 Quad Core Processor LGA1366 2.66GHZ Bloomfield 8MB LGA1366 4.8GT/S - BX80601920 In Canada.
NCIX.com - Buy EVGA GeForce GTX 275 633MHZ 896MB 2.26GHZ DDR3 PCI-E Dual DVI-I HDTV Out Video Card - 896-P3-1170-AR In Canada.
NCIX.com - Buy Corsair TX750W 750W ATX 12V 60A 24PIN ATX Power Supply Active PFC 140MM Fan - CMPSU-750TX In Canada.
NCIX.com - Buy Corsair XMS3 Dominator TR3X6G1600C8D 6GB DDR3 3X2GB DDR3-1600 CL 8-8-8-24 Core i7 Memory Kit - TR3X6G1600C8D In Canada.
Newegg.ca - Hanns·G Hi-221DPB Black 22" 5ms Widescreen LCD Monitor 300 cd/m2 1000:1 Built in Speakers - LCD Monitors
Might change the monitor
Old September 4, 2009, 06:54 PM
SugarJ's Avatar
You didn't say you were going with a whole new build! Those are good parts.
Are you aware antec has the new 900 Two? You may like it better. And are you overclocking at all? If so, don't forget an aftermarket cooler.
Age of Conan Zankras Gaming 53 July 25, 2009 11:35 AM
Age of Conan encorp Gaming 14 October 15, 2008 08:02 PM
Sign up for Age of Conan Beta testing Babrbarossa Gaming 0 April 3, 2007 01:13 PM
