Old September 3, 2009, 05:05 PM
Cranky's Avatar
Default Exttended Desktop not showing taskbar, icons etc.
This is a Vista setup with a HD4870x2. Here's the problem, I have my LCD TV hooked up as my second monitor, and while I can see the wallpaper on the LCD TV and can move my mouse pointer, and even drag icons over from my main monitor I can't execute anything on that monitor unless I make it my main monitor. I was under the impression that I could execute different things simultaneously on both screen. Such as having two separate browser windows open, one showing video while surfing in the other. What step have I missed in setting it up?
Asus P5K Deluxe / Intel Core2Quad Q9550@8x425@3400mhz(1.225v) / Arctic Cooling Freezer 7 Pro / 4Gigs DDR2 1066mhz(5-5-5-15) Corsair Dominator / Diamond HD4870x2 / Asus Xonar / WD Raptor 74gb / Hitachi 160GB / Antec Quattro 850w / Logitech Z-680 5.1 / Dell Ultrasharp 24" / 2 LG Optical Drives / Vista Ultimate 32bit / A tower that's been drilled, cut, and bent to fit all of my fans
Old September 3, 2009, 05:07 PM
gingerbee's Avatar
you can but tool bars and stuf like gaming will only be on the main monitor
Old September 3, 2009, 05:12 PM
Cranky's Avatar
I have seen videos where a desktop was extended to a second monitor and it was an exact clone of the main. My using the dvi to hdmi converter wouldn't have anything to do with it would it?
Old September 3, 2009, 05:13 PM
Infiniti's Avatar
You can get Ultramon to make another taskbar on the second screen, but you can only game on your main screen. Of course, you can drag a media player or browser to the other screen and watch a video there, but you'll have to have another browser open on your main screen for anything else.
Old September 3, 2009, 05:16 PM
Cranky's Avatar
So what your saying is that by default all I should be seeing on the second monitor is the wallpaper itself?
Old September 3, 2009, 05:19 PM
Infiniti's Avatar
And whatever you drag over, yeah.
Old September 3, 2009, 05:21 PM
Cranky's Avatar
Alright, I will try and drag my browser over, and post back later to let you know of my results.
Old September 3, 2009, 05:28 PM
bissa's Avatar
i think you can expand your browser onto the second screen but that would be quite difficult to read and would not really do too much for browsing anyways.
Strong like hummingbird, swift like oak.
Old September 3, 2009, 06:58 PM
jcmaz's Avatar
you'll only see the wallpaper. beware if you are using MediaPlayerClassic do not drag the window while playing a movie or it will freeze your computer.
-Plato
Old September 3, 2009, 07:28 PM
element291's Avatar
Lol its never frozen mine, it just makes the size all wonky and it wont go fullscreen properly.
| ASUS P8Z68-VPRO | Intel i5 2500K | 8Gb Patriot Viper Xtreme | 2x 60gb OCZ Solid 3 SSD | EVGA GTX260 Core216 |
Win7 not showing..... kruzn4evr O/S's, Drivers & General Software 6 May 28, 2009 12:31 PM
Making icons in ubuntu biff O/S's, Drivers & General Software 10 January 8, 2009 06:09 PM
Nothing showing up on screen klaiboi Troubleshooting 1 October 26, 2008 12:21 PM
Show us your desktop (YOUR REAL DESKTOP) probationer Off Topic 5 August 11, 2008 05:32 PM
TaskBar Shuffle enaberif O/S's, Drivers & General Software 0 January 6, 2007 12:28 AM
