Old August 29, 2009, 05:08 PM
Default Graphics cards and Memory
What are the advantages to having more memory intensive video cards?
Right now i own a 9800 gtx with 512mb.
Right now i'm running Vista 64 bit with 8 gb ram.
When i try Can i run it on nzone for games it tells me i have 2.5gb of video ram.
I'm confused and looking for answers.Can anybody enlighten me?Peace.
Old August 29, 2009, 05:37 PM
Unknownm's Avatar
only advantage I see with a video card with more memory is for GTA 4. Normally the higher resolution you play the higher the memory count is but 512MB is plenty for any standard game.
Has of the nzone telling you have 2.5gb of video card ram I'm not sure
Old August 29, 2009, 06:05 PM
MpG's Avatar
MpG MpG is offline
The whole point of video memory is to let the video card hold all the necessary information itself, rather than having to constantly fetch and send to the computer's main memory. As a result, once you have enough for a particular program, adding more doesn't really have any effect. It's when you don't have enough that the card is forced to use your regular RAM for storage, which is far slower in comparison, and will generally make your frame rates tank something horrible.
Not sure what the hell requires 2.5GB of video memory, but with higher-end cards, it's actually fairly easy to fill 512MB , which is why there's a lot to be said for 1GB cards, especially since they're usually not that much more expensive.
Perineum's Avatar
Generally speaking, more video card ram does not mean much or no performance increase at all.
The video card RAM is only really there for 3d use for holding the textures that wrap around objects.
In a 2d desktop use in say, WindowsXP, you only need 8 megs of RAM total to run a 24 bit screen at 1600 x 1200
So really, would you take a 9800GT with 2 gigs of RAM over a GTX285 card with half that amount?
Sure, you could load some beautiful looking textures into that 2gb of ram, but could the card manipulate it in real time? Likely not....
Anyway, I digress... could possibly be that NZone 'sees' some sort of buffered video ram from memory like AGP Aperture. My card has 896 megs of ram and I have 8gb....
Old August 29, 2009, 06:45 PM
Default Continuation
My mistake this is what it says:
Nzone i picked Crysis then chose can i run it.
Video Ram:Required-256mb You Have 4gb
Now enlighten me again.
Old August 29, 2009, 08:33 PM
Perineum's Avatar
I picked crysis as well... it told me that I have 2.9gigs of video ram. I have no idea why....
Old August 29, 2009, 09:05 PM
Safearus's Avatar
As far as I know Crysis by default detects your GPU memory + some of your RAM and tells you that this is your video memory. Someone please correct me if I'm wrong though
Old August 29, 2009, 09:28 PM
belgolas's Avatar
Well there are some games that need more than 1 GB of ram but there are not that many and only at extreme resolution and AA. So Crysis at 2560 x 1600 with 16xAF and 16xQAA almost takes up 2GB of V-RAM. GTAIV takes a lot of V-RAM as well. It is a benefit but only for rare cases. Also it is a myth that more ram is always better. A 9600 GT with 2GB of ram will not outperform a 9800 GT with 512MB of ram. Also generally if you need more than 1GB of ram you are going to need multiple video cards anyways. For most games though 512 is enough under 1920 x 1200.
Sponsor a child!
Fight poverty.
Qoute by Perineum
"ID10T. I just BETCHA he's got 9 toolbars on his web browser right now."
Old August 29, 2009, 09:41 PM
But will a 9600gt 2gb out perform a 9600gt 512mb?
Old August 29, 2009, 10:23 PM
Killswitch's Avatar
My guess would be no. If we were talking about a GTX280 or a 4890 then the answer would certainly be different, but I don't think a 9600GT is powerful enough to utilize any more then 512MB in the first place.
Mushkin Looks to Produce ATI Graphics Cards FiXT Press Releases & Tech News 13 July 21, 2009 02:08 PM
need advice on graphics cards and hdd dubbaz New Builds 17 January 21, 2009 02:57 PM
Club 3D Introduces GeForce 9500 GT Graphics Cards MAC Press Releases & Tech News 0 July 29, 2008 10:24 PM
First Look: NVIDIA GeForce 9500GT 55nm Graphics Cards MAC Press Releases & Tech News 11 July 9, 2008 06:42 PM
The Best Gaming Graphics Cards for the Money: March 2008 vertex112 Video Cards 2 March 7, 2008 11:38 AM
