Old August 28, 2009, 04:02 PM
Shadowmeph's Avatar
Default to run sli do the cards have to be the same?
I am wondering if when you run sli that all your Nvid cards have to be the same or does it really matter much?
Old August 28, 2009, 04:29 PM
shayan288's Avatar
Yes it ahs to be the same. You can SLI a gtx 260 core 216 and a core 196 and it would matter (i think its 196, cant remember), and you can SLI a sc card with an ssc card. It just has to be the same.
The 288
Q9550 E0 stepping @ 4Ghz
Gigabyte EP45 UD3P
G.Skill pc2 8500 1066mhz RAM
Western Digital 250gb
Antec 1200
XFX HD5970
Steelseries Xai Laser Mouse
Windows 7 Ultimate x64
Old August 28, 2009, 04:36 PM
Arinoth's Avatar
To my knowledge they have to be the same generation of card, that's it
Here I am: here I remain
Old August 28, 2009, 04:41 PM
rjbarker's Avatar
^ correct.
280 n 280 / 260 (192) n 260 (216) (( will provide only 192 Shaders though)) / 275 n 275 / can all be SLI with each other (same model), regardless of Brand or Clock Speeds.
If Cards have different stable Clock Speeds, such as one is stable at 675 / 1200 and the other is unstable at this speed, run the lower Clocked Card in the primary PCI_E Slot, running the other way around will result in instability.
Firestrike Extreme: 23.772K
https://www.3dmark.com/fs/17562471
Timespy: 18.613K
MARK 11: 40.185K
https://www.3dmark.com/3dm11/13079691
Old August 28, 2009, 04:43 PM
shumway's Avatar
Well they kind of have to be the same but not spot on.
You obviously can't take 2 differnt cards like a 9800 and a 260 and sli them.
Both have to be same as in 9800 with a 9800 and have the same amount of stream processors,You can't take 1 that has say 112 and pair with 1 that has 96 etc.
As long as the stream processors are the same for both cards it really dosen't matter about clock speeds either.
Hope that kind of made sense
Arinoth's Avatar
Can't you also SLI a 9800 GT with like a 275, or a 260 with a 275, i thought that was also possible, however i could easily be mistaken
Old August 28, 2009, 04:51 PM
Has to be same gen and same clocks.
Otherwise it gets all wonky.
Old August 28, 2009, 04:59 PM
rjbarker's Avatar
this is not entirely true...as I stated..GTX 260 w 216 Processing Cores (stream processors) CAN indeed be paired in SLI with a GTX 260 192 Processing Cores.........however, the additional Processing Cores will not be utilized....only the 192....but it has been proven to work just fine
Timespy: 18.613K
MARK 11: 40.185K
Old August 28, 2009, 06:59 PM
chrisk's Avatar
Folding Captain
Hey guys; I have a question about SLI too as I am currently testing something.
In my Asus P6T, I have three PCI-E slots. The two blue ones are x16, and I believe the third at the bottom is x8:
I want to keep my cards in the current slots as pictured above (two cards, but in the 1st and 3rd slot). Are there any potential issues running SLI in this manner? I have to use the tri-SLI bridge with the middle connector disconnected, and the middle slot unpopulated. Is this advisable?
Fold for team #54196
Old August 28, 2009, 08:23 PM
rjbarker's Avatar
Chris....cannot see this as being a problem at all......when I was running 2x SLI I too chose this config as it allows for "air flow" between the Cards. The 16x n 8 x vs 16x n 16x will only be slightly noticeable running Benches.....I have no experience folding so not sure how it will affect it, but I would guess minimally.
As far as your SLI Bridge goes, apparently the new 180.xxx Drivers eliminated the need for the Bridge ( this was confirmed to me on the Evga Forum quite some time ago). I have mine installed as I like the way it looks.
On my Evga X58 vanilla board (had it prior to this Classified 759), I experimented with using my 2 280's in top two Slots and top n bottom Slot...found no performance difference at all.....better air flow with the latter though..
Lots of enthusiasts use the Tri Sli Bridge instead of the 2x SLI Bridge as it looks better....
Timespy: 18.613K
MARK 11: 40.185K
Can you sli two different 200 series cards? andynerd Video Cards 6 June 6, 2009 07:31 PM
3DMark Vantage Run - Core I7 280 SLI rjbarker Overclocking, Tweaking and Benchmarking 24 April 7, 2009 07:53 PM
Can you Sli 2 different cards- element291 Video Cards 24 February 27, 2009 11:50 AM
WTB a used 7600 GT card, and a power supply good enough to run those sli free2fly Buy/Sell & Trade 7 December 22, 2007 06:04 PM
Can EVGA 8800GT Superclocked run SLI? drumsonly2002 Video Cards 3 December 13, 2007 05:39 AM
