Old August 24, 2009, 09:07 PM
Dar_ell's Avatar
Default GTX275 vs 4890
This might be a really easy answer but i want feedback from HWC, i been reading a bit on a web and the site i'm basing most of my opinions on this site Radeon HD 4890 vs. GeForce GTX 275 - The Tech Report - Page 1. I'm going to be buying a graphics card sometime tomorrow or the day after so fast responses are awesome, i'll be only purchasing from my local CC (canada computers).
From reviews i see that the 4890 it runs cooler, and uses less power, but i heard it a bit louder then the 275gtx. From their benchmarks i see that the performance is pretty close. I like the idea of a nvidia card though (might fold just for the fun of it ). Also i never tried a nvidia card in my rig, so it might be fun i guess? replacing my 4850 for a 4890 just seems.. i can't explain it just seems boring to me. haha i know im basing my purchase on what amuses me but thats what really matters to me i guess.. i don't know.. anyways i will not consider CF a 4850, i already sold it anyways .
oh btw don't mention the new cards coming up, i need to buy this card soon
"My brother is dead. He's not here Anymore. But on my back, and in my heart...He lives on in me. I will make a hole through heaven itself, even if that hole becomes my grave. As long as I break through, I will be victorious.Who the **** do you think I am?"
Old August 24, 2009, 09:31 PM
MonsterSound's Avatar
Like most reviewers have stated, it's a pretty close match between the two. Some, like I, give the edge to nVidia, but that's a battle hardly worth arguing over. Price is relatively close with the 4890 a bit cheaper on Sale than I have seen for the 275. Lower Noise under load & less power drawn on idle, gives the edge to nVidia, less power drawn under load gives the edge to ATI/AMD. Folding goes to nVidia so if you want to contribute to the folding effort, go for nVidia (and welcome to the folding club if you do;).
There are custom cards on both sides. I picked up the MSI 275 Frozr OC (currently $229 at NCIX (ar)) with its HSF solution which is cool and quiet based on this HWC 275 roundup review which you should read if you haven't already. The review compares several 275's with the 4970.
Either are xlnt powerful cards at reasonable price points imho.
Code:
 my Heatware,  RFD &  eBay
MAIN: i5 3570 @ 4.5Ghz wH100 / evga GTX780 SOC / MSI Z77A-G45 / 8gb G.Skill 2133 1T / 30" 2560x1600 / Antec P280 / PCP&C 950w / Intel 520 SSD 240gb / Eclipse / G3-Lazer / z5300 / Win7 Pro64 / APC Xs1300
HTPC : nMedia6000B / AMD X2 4400+ / M2A-VM / Corsair 4GB 800 / LiteOn Blu-Ray / 8800GT / Samsung 46"LCD / 2x2TB / OCZ500 / ATI550 / Wrless Kbrd & Rmte / z-5500 / Win7Pro / APC700
"You must be the change you want to see in the world"
- Mahatma Gandhi
Old August 24, 2009, 09:49 PM
Dar_ell's Avatar
I am soo glad that CC has Canada Computers - Video Cards > PCI-Express Cards > Powered By nVidia : MSI N275GTX Twin Frozr OC nVidia GeForce GTX 275 Chipset (633Mhz) 896MB GDDR3 (2268Mhz) Dual Dual-Link DVI PCI Express 2.0 Graphics Card.. Now the moment of truth is when i walk through that door and ask for the MSI GTX 275, will it be in stock or not. i hope so badly it will. i'm leaning towards nvidia side, i never had any support experience with MSI .. does anyone?
Old August 24, 2009, 10:00 PM
Default 2c
Just a note that the CC page seems to have the correct Part Number: N275GTX Twin Frozr OC, but posted the speed/specs for the non-OC version. Check the front box cover (lower right) and it should have "OC Edition" printed (should have N275GTX Twin Frozr OC on the serial number, bar code sticker thingy too).
XLNT price btw
I suspect the OC versions have been binned to overclock quite well as all that I have talked to with the MSI 275 OC versions have easily pushed past 700mhz.
Also the CC page says that the warranty is 1 year when it is actually 3 years. btw, MSI does have a Richmond Hill office for service though I haven't used it.
Code:
- Mahatma Gandhi
Old August 24, 2009, 10:01 PM
Dar_ell's Avatar
Sounds even better, thanks for the heads up! If i ever bought the wrong card i would facepalm..
Old August 25, 2009, 03:54 AM
I got a 4890 and I underclocked it to a point where I can lower the fan to an inaudible state and lower the temps by 10-15 degrees for when I am not needing it.
When I need it, I overclocked it as much as I could which is to 970 Mhz GPU clock and 4600 Mhz Memory Clock. At that point, it is loud, but since I have sound when I play games, I don't really hear it.
I hope my experience with my 4890 can help you a bit.
Old August 25, 2009, 05:26 AM
Dar_ell's Avatar
I would really consider the 4890 if my local CC had some better selection of it, i think they only hold the ASUS, sapphire and MSI ones. If they had XFX ones i would be thinking it over.
Old August 25, 2009, 12:38 PM
I just picked up one of these Saphire Vapor-X 4890. The fan is virtually silent even when you crank up the RPM's, and it comes out of the box mildly overclocked. It's a breeze to overclock even further using Catalyst Control Centre.
Highly recommended, and a good price from CC (better than the price I paid a week ago at another place).
Canada Computers - Video Cards > PCI-Express Cards > Powered By ATI : Sapphire Vapor-X HD ATI RADEON HD 4890 1GB GDDR5 Dual Display (HDMI/DVI/VGA) HD Audio Shader Model 4.1 800 Stream Processor PCI-Express 2.0 Graphics Card.
Old August 25, 2009, 01:12 PM
JD JD is offline
Yup they're decent cards. And that's nearly $50 less than I paid about a month ago
Definitely not silent though, once the fan speed gets up past the 60% mark, I can surely hear it over my rather quiet case. Mine peaks at about 90C and 80% fan after running OCCT-GPU for like 30min. In games though it doesn't seem to ever get that bad.
Old August 25, 2009, 01:27 PM
cdn_Madrach's Avatar
As far as Msi Richmond Hill office I just used it for my Wind Netbook and got what i consider was excellent service, took 15 days door to door using Canada post. I live In New Brunswick so nearly a week was shipping.
Intel e8400
Asus P5q pro
Mushkin Redline 4gb
Silverstone Strider 1kw modular
4870x2
Ocz Vendetta 2
Top deck Tech Station
Samsung dvd
4890 vs GTX275 (VALUE) wonton1017 Video Cards 20 August 1, 2009 10:05 AM
Toxic HD 4890 or Vapor-X HD 4890 AmuseMe Video Cards 10 July 20, 2009 03:54 AM
gtx275 stuck in 3d mode somecanadianguy Video Cards 0 June 21, 2009 11:41 AM
Overclocking a GTX275... somecanadianguy Overclocking, Tweaking and Benchmarking 7 June 15, 2009 09:49 PM
GTX275 Installation? somecanadianguy Video Cards 4 May 29, 2009 12:13 AM
