Old August 15, 2009, 12:45 AM
ToXic's Avatar
Default clocking 4870 x2
so today i started tinkering a little in CCC and clocking my card up a bit (GPU:777, MEM: 920) and i was wondering if i could push it further and maintain stable temps? im idling at about 66 right now.
My issue is that the computer is in the basement with the door off with these readings, and when done with will be top floor with door closed.
I'm back, baby.
XPS 9560
Old August 21, 2009, 07:41 PM
I normally don't post much on forums and read them alot. But you have perked my interests with your posts.
Anyhow, the only way you are going to find out if your OC is going to be stable is by doing it in small increments and then running a stress test on it.
As stress test is about 12-24 hours of constant load. Not 1 hour. There are hundreds, if not thousands of sites on the internet that have help on OC'ing your video card. I would suggest a search engine as your starting point
Old August 21, 2009, 09:04 PM
Also maybe keep your fan speed fairly high to start and then when you believe you're stable bring it down a bit at time to see what temps you get.
Old August 22, 2009, 01:40 AM
get a GPU full cover block, then you can clock it higher easy
got my cores at 839 each
4870 1GB clocking cadaveca Video Cards 21 February 17, 2009 03:03 PM
Need a solid Over Clocking Ram cwestwell New Builds 16 October 9, 2008 01:13 PM
Q9550 clocking @ 2.66ghz instead of 2.83ghz ricknash61 Overclocking, Tweaking and Benchmarking 4 September 2, 2008 06:57 PM
Over Clocking Ram mattydies Overclocking, Tweaking and Benchmarking 12 January 19, 2008 03:59 PM
e6600 Over clocking limit? mattydies Overclocking, Tweaking and Benchmarking 12 December 21, 2007 01:03 PM
