Old August 10, 2009, 08:29 PM
bkh2's Avatar
Default Quadro and GeForce at the same time?
I currently have a GTX 275. I want to get a Quadro card as I am beginning to use CAD software.
First off, I know that putting these cards in SLI in not an option.
I want to put one card in the first PCIe slot and the second card in the second PCIe slot.
I will then connect one monitor to the GeFore card and another monitor to the Quadro.
I've read that Vista will not support multiple drivers, but XP and Windows 7 will.
Assuming this works, will I have the Quadro performace on one monitor and GeForce performance on the other?
Old August 12, 2009, 02:07 PM
The configuration might work, but just to be on the safe side, I would get another GTX 275 instead of the Quadro.
Old August 12, 2009, 10:58 PM
bkh2's Avatar
It's not so much that Solidworks is laggy, but rather it is inaccurate. I don't think another gamer card will help my antialiasing and accuracy. Also, when I zoom in and out, it sometimes chokes up for a second, and then it snaps to the view it should have been at.
Old August 13, 2009, 07:12 AM
Sushi Warrior's Avatar
Quadro cards are the only things that work properly for that. However, there are certain processes that can be completed to make any normal card into a Quadro that involves flashing the card.....
Old August 13, 2009, 07:37 AM
Sagath's Avatar
And the best part about this is you can do it with last gens cards. Which means its cheap;
8800gt to FX3700
8800gtx to FX4600
GTX260 to FX4800
GTX280 to FX5800
Choose your poison. But I know for the price difference, I would be willing to risk it and flash it.
Old August 13, 2009, 08:02 AM
Perineum's Avatar
Heh, hmmm.... $140 after MIR or $1799 for the FX4800. Tough choice
Old August 13, 2009, 08:53 AM
Dr_BenD_over's Avatar
Fallen Folder
I thought you could trick the Quadro drivers into thinking a card was a Quadro by editing the NV4_disp.inf and you didn't have to flash the BIOS.
All's well that's Haswell
Old August 14, 2009, 10:44 AM
bkh2's Avatar
The problem with that is that Rivatuner's thing for editing the card's drivers is not supported by Vista, or so I've read. Otherwise, I'd totally do it. If I'm wrong, please let me know.
BTW, by Flashing, do you mean soft modding?
Quadro Soft-Mod for Geforce cards??? somecanadianguy Video Cards 4 May 31, 2009 05:07 PM
Question if anyone has the time Soultribunal HardwareCanucks F@H Team 5 February 18, 2009 12:22 PM
Geforce + Quadro enzeo Video Cards 2 September 30, 2008 07:24 PM
BFG GeForce 8600GTS OC or XFX GeForce 8600GTS? Song Video Cards 3 August 31, 2007 11:01 AM
