Old July 31, 2009, 05:02 PM
electronique's Avatar
Question 9600GSO @ 1280x1024
hello guys, it`s been a long time
I need some piece of advice from you - i have a galaxy 9600gso 384mb/192bit and I`m currently playing on my 1280x1024 Sony LCD work of a snobart.
Is it worth it the changing to 9800GTX (or 250gts =the same thing) ?! I don`t go higher than 1280x1024 ... I mean, I thought I should buy a good cooler, OC my 9600 and wait till the dx11 cards appear, then make a decisive change.
The only game who knocked out my card was GTAIV. *same res, medium &low img quality/rendering - barely some AA* Nevermind, I`m just waiting for Diablo3....
Tell me your opinion about this... i`ll appreciate it
Old July 31, 2009, 05:33 PM
jcmaz's Avatar
i would w8 till the new card b/c the 9600GS0 is still a competent card for many games. Why don't you lower your res for now?
-Plato
Old July 31, 2009, 05:34 PM
1280x1024 can be used with a 8800GT.
Trust me its all I use.
Old July 31, 2009, 06:46 PM
curtispan's Avatar
I'm using an 8800gs which is basically the same card, running games at 1680x1050. Although the only game I play consistently is TF2, I jack all the settings up to max. HDR, AA, the works. My card still runs the game without a hitch, and this is on an e5200 @ 3.0Ghz.
Honestly, if you want to really get your moneys worth, get an XFX 4850 from NCIX. You can pricematch it down to about $100 Newegg.ca - XFX HD-485X-YDFC Radeon HD 4850 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card - Desktop Graphics / Video Cards and it provides a great bang for your buck along with a stellar warranty. It will also become somewhat of a future proof if you stick to that resolution, and even if you got higher, it's still great!
Old July 31, 2009, 10:55 PM
That game is very CPU dependent. Upgrade to quad-core if you don't have one, OC if you do.
Old August 1, 2009, 12:48 AM
Thanks for all your replies.
I have a C2D E7200 @ 3Ghz (oc`ed for now, and no voltage mod) .
I think I`ll wait for a new dx gen.
Old August 1, 2009, 01:22 AM
That card will handle Diablo 3 fine at that res. Seriously, though, I'd start looking into a new monitor. Once you go widescreen, you never go back.
Compact 9600GSO cooling? chrisk Air Cooling 1 December 5, 2008 08:23 PM
Jetway nVidia 9600GSO 1536MB !!! Eagle Eye Video Cards 15 May 30, 2008 07:15 PM
