Old July 23, 2009, 03:46 PM
3 of 7's Avatar
Default Onboard for HTPC?
I'm changing some hardware around and I'm wondering if I should use the intel 82945G onboard or the Diamond Viper X1650 Pro 256 PCIE that I have lying around.
The fan on the 1650 is hella noisy so I'll have to rectify that, but I'm wondering if there is a reason to use it in the first place?
Nature always sides with the hidden flaw
Old July 23, 2009, 04:34 PM
Silvgearx's Avatar
why not?
i was able to play 720P on a P4 with a x1650 pro and still had 20%-30% headroom. without the gpu the machine would choke and restart :P
maybe you should turn down the fan on the x1650 pro to the regular settings. at 30% fan speed it idle at 52C should be no problem.
Old July 23, 2009, 04:44 PM
3 of 7's Avatar
Is the 1650 going to give me noticeably better video than the 82945G at 1920 x 1080? The onboard does just fine at 1280X1024 right now. I guess I should have asked if this onboard chipset will be ok at the larger res.
Old July 23, 2009, 08:40 PM
JD JD is offline
I don't think either are ideal for HTPC usage...
I love my HD4350, quiet, HDMI output, and has various video enhancements to make things look better. Cheap too
Old July 25, 2009, 09:25 AM
3 of 7's Avatar
Well, I went with the X1650 and hooked the fan up at 5v and it's pretty much silent. We'll see if it burns LOL.
Old July 25, 2009, 09:30 AM
"Quote This..."
Your onboard will not do 1080p
Old July 25, 2009, 09:51 AM
3 of 7's Avatar
That's ok, the tv won't anyways.
Old July 25, 2009, 05:47 PM
Silvgearx's Avatar
the on board won't do 1080p but the x1650 will.
i been wondering for a while which x1650 you have?
Old July 25, 2009, 06:43 PM
3 of 7's Avatar
It's a Diamond 256mg PCIE
Old July 30, 2009, 09:16 PM
3 of 7's Avatar
Well, looks like the X1650 didn't like the 5v fan mod and pooped the duvet.
I ordered an MSI 4350 with a passive HS for $39 at NCIX.
Motherboard with onboard GPU Cinmod01 CPU's and Motherboards 8 July 27, 2009 03:49 PM
Motherboard with onboard graphics? AbC-50 CPU's and Motherboards 9 May 5, 2009 06:03 AM
No sound off my Onboard or my soundcard Shadowmeph Troubleshooting 3 February 27, 2009 05:37 PM
Onboard E-sata not working Jonesy Troubleshooting 5 January 10, 2009 10:15 AM
What motherboard has really good onboard sound? HermesĄ˘ CPU's and Motherboards 7 December 22, 2008 05:39 PM
