Old July 23, 2009, 11:14 AM
Mulder's Avatar
Default PCI Express 2.0 vs x16
Can i run this video card on this motherboard if i can will i see any decrease in performance? also if any can recomend a better card for my system or anything go ahead.
Video card
BFG GeForce GTX 280 Video Card - OC Edition, 1GB GDDR3, PCI Express 2.0 x16, SLI Ready, (Dual Link) Dual DVI, HDTV, HDMI Support, VGA Support BFGEGTX2801024OCE in Canada at TigerDirect.ca
NCIX.com - Buy Gigabyte GA-P35-DS3L ATX LGA775 P35 1333FSB 1PCI-E16 3PCI-E1 3PCI SATA2 Sound GBLAN Motherboard - GA-P35-DS3L In Canada.
Old July 23, 2009, 12:08 PM
jcmaz's Avatar
You probably won't see and difference between PCI E 1.0 and 2.0 unless you are running TRi/QUAD SLI/XFire.
-Plato
Old July 23, 2009, 12:14 PM
artistpavel's Avatar
Tigerdirect is expensive store, Shopbot - Compare prices - Canada - Price Comparison - Comparison Shopping will give you better price for GTX 280, and I would suggest to go with GTX 275, newer tech, equal performance, cheaper/often on sale.
х58forLife
Old July 23, 2009, 12:26 PM
JD JD is online now
GTX275 or HD4890 would be better choices IMO. And yeah, shop around.
Any card will run fine in that motherboard though. I highly doubt the performance would be any lower than a PCI-E 2.0 board.
Old July 23, 2009, 12:41 PM
Many cards haven't fully utilized the 1.0 spec, and they are releasing PCI-E 3.0 in 2010.
х58forLife
Old July 23, 2009, 01:37 PM
Mulder's Avatar
I just pulled the trigger on the GTX 275 Superclocked, the superclocked and retail card were the same price with the same $20 mail in rebate. Are the cores and memory of higher quality on the superclocked models?
EVGA GeForce GTX 275 Superclocked 648MHZ 896MB 2.376GHZ DDR3 PCI-E Dual DVI-I HDTV Out Video Card
NCIX.com - Buy EVGA GeForce GTX 275 Superclocked 648MHZ 896MB 2.376GHZ DDR3 PCI-E Dual DVI-I HDTV Out Video Card - 896-P3-1171-AR In Canada.
EVGA GeForce GTX 275 633MHZ 896MB 2.26GHZ DDR3 PCI-E Dual DVI-I HDTV Out Video Card
NCIX.com - Buy EVGA GeForce GTX 275 633MHZ 896MB 2.26GHZ DDR3 PCI-E Dual DVI-I HDTV Out Video Card - 896-P3-1170-AR In Canada.
Old July 23, 2009, 01:55 PM
The cores on factory overclocked cards are supposedly binned (tested for performance), however some say it's just marketing. I bought same Superclocked card and flashed with next step up FTW version bios, works just fine.
х58forLife
Old July 23, 2009, 01:56 PM
Arinoth's Avatar
Originally Posted by artistpavel View Post
Many cards haven't fully utilizing the 1.0 spec, and they are releasing PCI-E 3.0 in 2010.
Yep, its like quad cores and 6/8 cores, the hardware foundation is there, however most software doesn't utilize it
Here I am: here I remain
Old July 23, 2009, 02:03 PM
Mulder's Avatar
whats the overclocking on these cards like without flashing the bios? I don't really want to get into bios flashing the first day i get the card lol, maybe in a few weeks. I take it flashing voids evga's waranty?
Old July 23, 2009, 02:06 PM
yes, it voids the warranty, the better way is to use EVGA Precision overclocking utility that comes with card, also you get free game, 3DMark Vantage code, Step Up and other sweet goodies after you register card.
х58forLife
Does the 9400 GT 1024MB PCI Express 2.0 work on PCI Express x16 slot? aleo Video Cards 9 June 8, 2009 05:47 PM
TV card looks wrong in PCI express x16 slot cappaj1 Video Cards 4 June 4, 2009 06:34 PM
PCI Express 1.1 Bottleneck? Chos3n CPU's and Motherboards 3 April 16, 2009 06:08 AM
PCI-E X16 and X1 question Toronto122 Troubleshooting 7 April 2, 2009 07:37 AM
pci express evzonas Video Cards 3 August 31, 2008 08:02 AM
