Old July 19, 2009, 02:54 PM
Default 750W PSU enough?
So, I just purchased 3 x GTX 260 Core 216's (Superclocked version's from EVGA) And I'm not sure if my PSU is really going to be able to support 3 cards, (Right now I've got the Corsair TX750W) With 1 60A 12+v Rail. I'm planning on getting a new PSU as soon as I've got the money for it, but do you think the 750W will hold up until then?
System Specs:
EVGA 790i SLI FTW Digital PWM
Intel C2Q Q8400 @ 3.66 Ghz
8 GB OCZ DDR3 1600 Ram
3 x GTX 260 Core 216's Tri-SLI
2 x 500 GB Seagate's running in RAID 0
1 x 1 TB Seagate For storage.
Thanks,
Forthelulz
Old July 19, 2009, 02:58 PM
System Specs:
Corsair TX750W PSU
Thanks,
Forthelulz
Old July 19, 2009, 03:00 PM
gingerbee's Avatar
i don't think that's gonna cut it
Old July 19, 2009, 03:02 PM
Should be okay, but it's generally best to use a PSU that has enough native connectors for your components.
If you decide to upgrade, I'd recommend the HX850 with 6 PCIe connectors.
Old July 19, 2009, 03:12 PM
gingerbee's Avatar
unless you plan on running it at 90% all the time then i would get something bigger. jmo
Old July 19, 2009, 03:26 PM
Won't get near 90%, 3x ~110W for GPU & ~160W for the rest.
Old July 19, 2009, 03:41 PM
Silvgearx's Avatar
you be fine, i doubt if you can use all 3 gpus at 100%. so maybe 600w max power draw? (i don't know)
and your running a duo core, can that thing even keep up on 1920x1200 resolution and up?
Old July 19, 2009, 03:44 PM
shayan288's Avatar
lol three posts of the same thing...?
The 288
Q9550 E0 stepping @ 4Ghz
Gigabyte EP45 UD3P
G.Skill pc2 8500 1066mhz RAM
Western Digital 250gb
Antec 1200
XFX HD5970
Steelseries Xai Laser Mouse
Windows 7 Ultimate x64
Old July 19, 2009, 03:46 PM
rapmaster's Avatar
uhhh...no, the GTX 260 are 170W each
Quando omni flunkus moritati
Old July 19, 2009, 03:48 PM
Silvgearx's Avatar
No kidding eh, for a sec i though i was going crazy due to a lack of sleep
seriously you need to read the rules and the sections topics carefully
THe other two
http://www.hardwarecanucks.com/forum...su-enough.html
750W PSU enough?
nvidia GPU mix = EPIC fail? PSU 750W? Help this n00b out! Silvgearx HardwareCanucks F@H Team 9 April 6, 2009 04:08 PM
[FS] E8400, 750W Silencer PSU, P5K Deluxe mobo DavidDemise Buy/Sell & Trade 9 March 22, 2009 02:15 AM
Moduler 750W+ PSU Recomendations k4kman Power Supplies 18 March 17, 2009 08:31 AM
[WTB] WTB: Case and PSU 750w+ --- Tonight Table21 Buy/Sell & Trade 0 February 7, 2009 03:55 PM
750W vs 1000W vinister Power Supplies 0 April 4, 2008 09:52 PM
