Old July 19, 2009, 01:44 PM
Post Wondering about having 2 video card: ati AND nvidea on same motherboard
Hello all,
I found out that the new generations of motherboard could possibly do so.
Yet, i got myself an old motherboard from Foxconn digital life one.
I am about to put my ati 4890 on it, and i am considering buying an old graphic card such as 8800 ultra or such...or any suggestion for a low budget.
to be able to enable that phys x engin on it.
1. anyone can suggest me something about that?
2. anyone already tried that?
3. Is it really impossible to configure etc?
thx for your time and answer.
Old July 19, 2009, 02:05 PM
Caldezar's Avatar
You are aware that you can't crossfire/SLI an ATI with an NVidia right?
Old July 19, 2009, 02:27 PM
martin_metal_88's Avatar
If you are Using XP, most of the time it will boot then go in windows try to load driver and after windows will says WTF!!!! BSOD and reboot. Becasue of a driver conflict.
If you are using vista, after the load of driver one of the 2 card will be ahutted down( the one in the second PCI-e slot ) and driver will probably shit in your hand some time like driver has loss and has recovered few second after.
If using seven, same has vista.
That's what happen most of the time.
Ask for more
Old July 19, 2009, 02:29 PM
You're going to give yourself a headache.
Old July 19, 2009, 02:44 PM
gingerbee's Avatar
just buy ati or nvidia and save your self the hassle
Old July 19, 2009, 03:51 PM
rapmaster's Avatar
I'm not sure, I think it will work for XP or window 7 but not Vista.
Anyways, you can always try and experiment.
EDIT: It actually worked for someone ATI+NVIDIA Physx??? yes - techPowerUp! Forums
Quando omni flunkus moritati
Old July 19, 2009, 06:05 PM
thx a lot especially rapmaster for showing me a shortcut through the headaches... ^_^
so i guess it is possible... its not just an idea or theorically an option
i guess ill have to buy one and make a review and try it for myself to see how it goes.
no the main time ill try to figure out if window xp 64 bits will cause a problem with the drivers etc.
thx for your time.
Old July 19, 2009, 07:47 PM
Here read this thread
and it does work in XP
http://www.hardwarecanucks.com/forum/video-cards/15458-4850-physx.html
Old July 19, 2009, 09:13 PM
JD JD is online now
If you REALLY need PhysX hardware support to play the 2 or 3 games that use it properly, you'd be better off finding an old used PhysX card that is just a pure PPU (physics processing unit).
Old July 20, 2009, 07:18 AM
Originally Posted by Frank Encruncher View Post
thanks now i just need to receive my case and get an alternativ power supply. I ll tell you guys how it went.
yes i thought of that too, but taking an pci express slot... jsut for that.
i mean the price of that card would basically be over 100.
which for that price i could find some 8800 ultra for the need.
besides if at one point i want to switch video cards... i could.
umm i need to think about it.
thx guys for your time and advice.
[FS] ATI X850 crossfire edition PCIe video card yamawho Buy/Sell & Trade 9 March 22, 2009 12:29 PM
LF-Cheap ATI video card that can output sound through HDMI. Gunner86 Buy/Sell & Trade 9 November 2, 2008 06:19 PM
FS: Ati Ultimate X1950 pro pci-e video card by sapphire with Just Cause 90$ Ottawa HonkytonkMan Buy/Sell & Trade 3 May 1, 2008 07:27 PM
