Closed Thread
Old July 16, 2009, 10:40 PM
AmuseMe's Avatar
Default Toxic HD 4890 or Vapor-X HD 4890
Im thinking of starting off with one of these, to replace my dead 4870X2, and than, adding another down the road. I am wondering though, whats the difference between the Toxic HD 4890 and the Vapor-X HD 4890.
I am using this mobo.
NCIX.com - Buy Gigabyte EP45-UD3P ATX LGA775 P45 DDR2 2PCI-E SATA2 RAID HD Sound 2GLAN 1394a CrossFireX Motherboard - GA-EP45-UD3P In Canada.
Old July 17, 2009, 04:41 AM
Go XFX. Best warranty.
Old July 17, 2009, 06:06 AM
martin_metal_88's Avatar
Toxic is a cooler desing looking like a 7900GTX and vapor-x are sometime overclocked a little and have a better cooler again. The direct contact surface in the vapor-x is copper filled in with copper scratch and water ( vapor ) same used for high end CPU cooler. So you have the best dissipation you can find in that type of cooler. The only problem with all these card is, the fan suck :) so the vapor can't do all the job it can do but it's already better.
Ask for more
Old July 17, 2009, 09:40 AM
AmuseMe's Avatar
I heard, from another post regarding my dead 4870X2 (There goes my new 4870x2...) to go with XFX, good warranty. True?
Old July 17, 2009, 09:42 AM
AmuseMe's Avatar
For XFX do I want their XT, or XXX(lol)?
Old July 17, 2009, 10:58 AM
yes they have a better warranty (double lifetime ). I never try their service at all. I think for myself that a GPU is pretty rare to died is you used it normally ( not like trying running Crisys on a so loved Voodoo 3:P ) So that's why I'd go ( personally ) for better cooled GPU. If you want to keep it a long time and push it to the limit then a full time warranty should be good.
Old July 17, 2009, 11:06 AM
Supposedly the Toxic has a better cooling setup as the fan blows across the memory while the Vapor-X's fan only blows across the chip. The Toxic is 960 core with 1.4v while the Vapor-X is only 870 core. Dunno what volts are supplied to the Vapor-X but I assume less than 1.4v. I also read somewhere that the Toxic allows for the core to be clocked up to 1100 while the other 4890's don't. Don't quote me on that though as I just read it somewhere. The Toxic's are what I am looking at for future purchases. Of course I am looking at the XFX Black Edition 1ghz if they would only hurry up and get them here in the US.
Graphic Cards - ATI Radeon HD 4000 - ATI Radeon? HD 4890 Black Edition
Overclockaholics
Old July 17, 2009, 01:56 PM
Vapor-x
I/O Output: Display Port+HDMI+DL-DVI+VGA
Core Clock: 870 MHz
Memory Clock: 1050 MHz, 4.2 Gbps
Toxic
I/O Output: Dual DL-DVI-I+HDTV
Core Clock: 960 MHz
Hope this helps.
Old July 17, 2009, 02:23 PM
AmuseMe's Avatar
Right now, what would you all say is the best 4890
Old July 17, 2009, 02:41 PM
JD JD is offline
I just got my Vapor-X from DirectCanada this morning.
Idles at 57C, load is around 77C. Totally inaudible over my other case fans (~1200rpm S-FLEX "F"s and Gelid Wing 12).
Haven't got to finding the stable OC just yet though. 970/1200 ran L4D fine but froze 3DMark06.
I'll be posting some comparison benchmarks to my HD4850 and pictures of it later today.
EDIT: Posted it: Sapphire Vapor-X HD4890 1GB vs HD4850 512MB
Closed Thread
anyone with watercooled hd 4890's ? bc_tileguy Water Cooling 9 July 12, 2009 08:15 AM
2x 275 or 2x 4890 bumfloss Video Cards 5 May 26, 2009 06:32 AM
4890 again...yeah i`m serious martin_metal_88 Video Cards 6 April 21, 2009 07:36 AM
4890 Spotted snoosebum Video Cards 7 March 29, 2009 06:40 PM
