Old July 8, 2009, 09:57 AM
Cowboy's Avatar
Default Asus 4890 Problem
Hey all,
This is not an easy problem, just so you know:
I have my 4890 in my W.C loop, with a full cover koolance block.
I have been trying for days to figure out why I could not get the Voltage tweak software to work.
After many different software trials, (different drivers, versions of the program, different OS) I tried going the hardware route. I took apart my stock cooler, took out the fan, and plugged it into my card (with the fullcover block still attached) and left the fan to hang there.
And what do you know, it works. I am able to use the program and increase the voltage on this puppy. The only problem: the fan is still hanging there, and its loud as hell.
I need to figure out a way to "trick" my card into "thinking" that it has a fan plugged in.
Either a software or hardware/mod solution will do. I will not mess with the bios unless it is the only way to fix it.
the fan has 4 wires in this order: blue (pwm wire), yellow (fan speed sensor), red(power), black(power).
thanks.
Old July 9, 2009, 01:37 AM
IRQ Conflict's Avatar
That's a good question. Although I fail to see why the fan status should have anything to do with it unless it is a fail safe. Do you have a compatible fan (four pin) that does not work that you can test this with? We need to know if it is triggered by RPM's or not. I don't understand why the fail safe would not rather be triggered thermally? Interesting stuff.
Old July 9, 2009, 04:29 AM
Cowboy's Avatar
I don't have an extra 4-pin fan to test it, but I agree that it is puzzling. A thermal fail-safe would have made more sense.
Hardware problem or HAL problem? andynerd Troubleshooting 1 March 7, 2009 09:03 PM
Asus P5Q-E MB wake up fan settings problem resolved 486 CPU's and Motherboards 0 February 26, 2009 10:06 PM
Asus P5K Premium wifi mobo problem kruzn4evr CPU's and Motherboards 5 July 4, 2008 12:28 PM
Sata Problem on Asus P5K-Deluxe WIFI/AP neurobashing CPU's and Motherboards 1 August 14, 2007 07:50 PM
