Old October 17, 2007, 01:59 PM
browner87's Avatar
Question Window?
Hey Sky, I see you've done this in a Gigabyte 3D Aurora 570! Which means your temps should reflect mine! Or will they? What Side panel did you use (or did you?)? Was it the window or grill or did you leave the side panel off? BTW Nice review - love the pictures!
Old October 17, 2007, 02:03 PM
SKYMTL's Avatar
HardwareCanuck Review Editor
Side panel closed with the perforated side panel. NON of my cooler reviews are done with the side panel open.
Don't forget to do my HD cage fan mod.
Old October 18, 2007, 01:02 PM
browner87's Avatar
Default Thx
K, I use the window, but I'm gonna cut a hole in it to mount a fan and I also have a 120mm fan on this side of the HD cage. Thx!
Old October 20, 2007, 07:49 AM
browner87's Avatar
Default Wow.
Wow. This thing lowered my eVGA eGe-Force 8600 GTS Superclocked's temps about 10 degrees C! A little big with a fan on it though for my liking if I ever went to SLI.
Old October 20, 2007, 08:22 AM
SKYMTL's Avatar
Told you!!!!!
Old October 25, 2007, 03:18 PM
browner87's Avatar
Talking Thx
Thanx, that's what I was banking on.
BTW - I can't seem to get to the 3D Aurora 570 page - I keep getting a 'page not found' pagewhen I try to go there and I wanted to post pics and info on a mod I did to make the side window tolerable. (actually very similar temps to no side at all).Any idea what's wrong?
Old October 25, 2007, 03:29 PM
SKYMTL's Avatar
http://www.hardwarecanucks.com/forum...se-review.html
Old December 2, 2007, 02:04 AM
Would this adequately cool an eVGA 8800GT 512MB card? I have a spare 1" tall heatsink from an old PII that I can dremel apart to serve as additional cooling for the VRM's. Given that, would this cooler do the job, not planning to push a huge O/C at all.
Sky I would certainly appreciate your voice. Thanks and Seasons Greetings.
If you're looking for computer parts in Canada, avoid tigerdirect.ca!!
AMD A64 X2 3800+ Toledo @ 2.5GHz - DFI Ultra-D s939 - 4x512MB OCZ Performance Series/Samsung OEM PC3200 - 160GB Samsung SATA2 - eVGA 8800 GTS 320MB SuperClocked - Antec Earthwatts 430W PSU - Antec PlusView 1000AMG
  #19 (permalink)
Old December 2, 2007, 02:47 PM
SKYMTL's Avatar
With the optional fan installed, yes.
Without it.....absolutely not.
  #20 (permalink)
Old December 3, 2007, 12:33 AM
Thanks SKY for the response,
I checked the TR website shortly after my last post and under the column "Compatibility" it says No:
So No from TR? But you said in your review of the eVGA 8800GT SC that:
"The length of the PCB is akin to that of an 8800GTS but the offset of the screws around the core matches that of the 8600GTS."
And you fitted the TR V2 on the 8600GTS in your review of the cooler. So....what's up?
I think I can trust your word, so let me know if I shouldn't. Could you confirm this one more time for me?
On another note, are you putting your V2 from the review up for sale? I would be interested assuming it would work with my card
And yes I certainly plan on using an 80mm fan to cool the card. Will I need to cool the VRMs for sure?
Coolink Silentator CPU Cooler Review Comment Thread SKYMTL Air Cooling 7 April 22, 2008 08:20 AM
Thermalright HR-03 GT Review Comment Thread SKYMTL Water Cooling 9 April 10, 2008 01:52 PM
Comment thread for Thermalright HR-03 Rev.A Review 3oh6 Water Cooling 5 November 6, 2007 11:09 AM
Comment thread for Thermalright HR-11 Backside Cooler Review SKYMTL Water Cooling 0 September 24, 2007 06:23 AM
Comment Thread for Noctua NC-U6 Chipset Cooler Review Supergrover Water Cooling 11 July 1, 2007 02:47 PM
