Old June 30, 2009, 01:38 PM
Default 2 x 9800 GTX+ : Quick Question
I have an EVGA and XFX 9800 GTX+
Will it be ok to SLI them or could I run into issues?
Comp1 (Mine) : ASUS P8P67 Pro, i5 2500K (4.5GHz), 16GB Corsair Vengeance, PNY GTX 580 1.5GB, OCZ Vertex 120GB SSD, 600GB VelociRaptor, Corsair 1000HX, Cool Master HAF 932
Comp3 (Wife's) : Asus P6X58D Premium, i7 950, 8GB Corsair Vengeance 1600 RAM, 2x1TB HD's, EVGA GTX 560Ti, Corsair 950W, HAF 922
Comp2 (Kids) : Intel DQ67SW , i5 2400S, 8GB RAM, EVGA GTX 570 SC, 1TB WD Black, Corsair 850W, Antec P183
Old June 30, 2009, 01:49 PM
jcmaz's Avatar
if ur mobo supports SLI, then go for it. Make sure ur PSU can handle it. Note that you might get similar performace in some games w/ one 9800GTX compared to 2 9800GTX b/c some games have crappy SLI support.
-Plato
Old June 30, 2009, 02:42 PM
rjbarker's Avatar
You'll be fine.....
Tri SLi "Procyon"
http://i30.photobucket.com/albums/c3...ant2/nice2.jpg
Evga 4.2 Ghz Club....
Tri SLi 580 MK11
http://i30.photobucket.com/albums/c3.../MK11Multi.jpg
Tri SLi 580 Vantage
http://i30.photobucket.com/albums/c3...ant2/60K-1.jpg
......Remember, keep your head up....and your stick on the ice
Old June 30, 2009, 03:10 PM
Prof. Dr. Silver's Avatar
Yes you can SLI them.... if one card is faster than the other... they will adjust speed automatically... however, your mobo does NOT support SLI... :(.... Your wife's mobo does :)
Hardcore Folding at it's BEST! HWC - TPU.... There can be only one team in front! TPU, can you smell our *sses already?
Old June 30, 2009, 03:20 PM
Arinoth's Avatar
You might want to make sure whatever power supply you has enough juice for you to run SLI as well, otherwise, well, it won't.
I would recommend doing what Prof suggested when the wife is out
Old June 30, 2009, 05:13 PM
Realityshift's Avatar
I was able to SLI an EVGA 9800GTX vanilla with an EVGA 9800GTX+ Superclock with no issues, you should be fine.
The Builders Hammer
Old July 1, 2009, 09:46 AM
bojangles's Avatar
You'll be fine. They're the same thing. Brand doesn't matter.
Old July 3, 2009, 04:46 PM
Is that true also for a EVGA 8800 GTS? So i can run a XFX or any other 8800 GTS 512? I have the EVGA and am looking for a SLI brother. thanks :D
Old July 3, 2009, 05:18 PM
bojangles's Avatar
As long as they're the same chip you're good to go.
Old July 3, 2009, 06:37 PM
Yeah what bojangles said, it doesnt matter what company makes it, only the type of GPU, the only place this doesnt cross is the 9800GTX to the GTS 250, you can SLI a GTS 250 and a 9800GTX+ but not the 9800GTX... As for the 8800GTS you just need another GTS and your good. Even if the 2 cards run different default clocks aka one is overclocked one isnt, the cards will run at the speed of the lowest card till you overclock them after ;)
The Builders Hammer
9800 gtx+ cable Q mattydies Video Cards 2 June 19, 2009 12:49 AM
[WTB] WTB PCIe GPU (Considering 8800 GTX / Ultra, 9800, GTX series or newer cards) S_G Buy/Sell & Trade 3 June 18, 2009 06:31 PM
quick quick can we do 4 gtx 285 sli? hohohee Video Cards 7 June 7, 2009 11:14 PM
9800 GTX+ vs Gtx 260 core 216 guinessftw Video Cards 2 February 6, 2009 03:26 PM
eVGA 9800 GTX KO+ DavidDemise Buy/Sell & Trade 14 September 17, 2008 08:52 PM
