Originally Posted by jdrom17 Only reason to buy the ROG HD4850 (which I'm guessing is the most expensive HD4850 out there) is the voltage control. Now if you don't plan to push this thing to its overclocking limits, then there really is no point.
It would be helpful to know what resolution you game and and your current games. Then it will be fairly easy to decide between a HD4850 or HD4870. |
I will be surely be OCing that card.
I will be playing mostly on 1680x1050 and sometimes I will play on 1440x900.
