Old June 22, 2009, 07:23 PM
Default increasing the voltage on a hd 4890
has anyone tried increasing the voltage on a 4890 yet ?
how did you make out ?
what program did you use ?
what were your results ?
thanks
Old June 22, 2009, 07:26 PM
"Quote This..."
I did the pencil mod to my 4850, worked great. Got 1.37v core (on water).
Old June 22, 2009, 07:38 PM
nice !
how much difference did it make on overclocking ?
before and after ?
Old June 22, 2009, 08:14 PM
"Quote This..."
If I recall I went from 750 to 830.
Old June 22, 2009, 11:33 PM
IRQ Conflict's Avatar
Haven't tried it but RBE from techPowerUp should work to edit the voltages on the HD 4890.
Edit: From what I've read the HD 4890 likes 1.4v for a speed bump to 1Ghz from the stock 1.325v 850Mhz. Watch your cooling though.
Old June 23, 2009, 12:02 AM
burebista's Avatar
Try this if you know what are you doing.
Old June 23, 2009, 08:07 AM
thanks
Old June 24, 2009, 09:37 AM
Cowboy's Avatar
as soon as I get my asus 4890 top, and as soon as I figure out how to do it, I'll post the card's bios on the forums.
It would allow you to use the software included to increase the voltage via software. (asus 4890 voltage tweak)
Old June 25, 2009, 06:03 AM
thanks but i would rather not flash the bios on my cards
how much more nb voltage. kyle_L Overclocking, Tweaking and Benchmarking 17 May 24, 2009 06:31 PM
Voltage setup when OC Wurmer Overclocking, Tweaking and Benchmarking 8 February 20, 2009 04:36 PM
Voltage advice. encorp Overclocking, Tweaking and Benchmarking 3 November 20, 2008 11:49 PM
Over Voltage a35599 Overclocking, Tweaking and Benchmarking 6 February 26, 2008 10:21 PM
What is Stock Voltage? mattydies Video Cards 10 October 19, 2007 09:01 PM
