Old June 18, 2009, 09:00 PM
mattydies's Avatar
Default 9800 gtx+ cable Q
I bought a used 9800 GTX+ from a friend a couple months back. It came with everything accept the special cable (that allows tv output among other things).
I have a cable from my 7800gt that "Looks" the same.
Are they compatible? I decided I should ask instead of plugging it in and hoping I do not fry the card ;)
Does the cable have a name?
ALSO
Is there a differance between 9800GTX+ cards which use 1 and 2 power cables?
Intel E8400 @ 4.TWENTY Ghz & counting
Ultra 120 Ext. w/ Dual Noctua NF-P12's
Gigabyte EP45-UD3P (Rev. 1.6)
Patriot Viper (2X2GB) 1066-5-5-5-15
Gigabyte 6870 Windforce (FINALLY)
Samsung SyncMaster 225BW (22" Widescreen - 5MS)
Western Digital 74GB Raptor X 2 (Raid 0)
Seagate 750GB - SATA 2 - 7200.10
Nspire X-extreme (CWT) 750W PSU
Audigy 4 Pro, Yamaha HTR, Cerwin Vega Speakers (5.1)
Antec 900 Case
SCYTHE Fan Controller w/ 4 extra Noctua NFP-12's
Old June 18, 2009, 09:48 PM
Silvgearx's Avatar
are you talking about the S-video cable to RBG?
if so they will work.
and you won't fry your card with a single plug in
Old June 19, 2009, 12:49 AM
Realityshift's Avatar
The 9800GTX+s that use dual cables tend to overclock better because they have more even and constant power, thats the only difference I saw between the 2 having owned both.
The Builders Hammer
[WTB] WTB PCIe GPU (Considering 8800 GTX / Ultra, 9800, GTX series or newer cards) S_G Buy/Sell & Trade 3 June 18, 2009 06:31 PM
9800 GTX+ vs Gtx 260 core 216 guinessftw Video Cards 2 February 6, 2009 03:26 PM
eVGA 9800 GTX KO+ DavidDemise Buy/Sell & Trade 14 September 17, 2008 08:52 PM
Overclocking 9800 GTX KO DavidDemise Overclocking, Tweaking and Benchmarking 1 July 29, 2008 08:24 PM
9800 GTX specs and dissapointing. belgolas Rumor Mill 21 March 26, 2008 07:27 PM
