Old May 30, 2009, 01:20 PM
Default bfg 7800 gs oc agp unlocking
just bought from ebay
where is the 24/16 howto?
don't se no one!
thanxxxxxxxxxxxxxxxxxx!!!
Old May 30, 2009, 02:32 PM
gingerbee's Avatar
what ?
Old May 30, 2009, 03:31 PM
He's referring to unlocking the other 8 masked pipes (shaders). These pipes are laser locked and can't be unlocked unless you have an engineering sample card which is very unlikely.
Old June 1, 2009, 05:24 AM
hi again
are you sure that agp version is lasercut?
these are not depending of the chip revision a1,a2,a3?
heres is how y have to done:
dump original bios whith nibitor.
taking bios from same board but called gt.
then locking in asci text format searching the pipelines blocked.
any photo from 1 chip lasercuted and another not?
thx (no, i don't read asci text but easy to compare diferences)
PD: ¿create a compilation of deblocked cards/pipelines in 1 post ? (heavily experienced ones needed)
Old June 1, 2009, 05:28 AM
mistake:
same agp/pci-e bridge from 6600 to 7950gt the br02!
where is the anonimous br01?
pd: not in a hurry thx!
BFG Free upgrade from AGP to PCIE Jonwall Video Cards 4 November 24, 2008 09:23 PM
FS: Video Cards 7800,7900,8600 FrankyG Buy/Sell & Trade 28 October 9, 2008 12:15 AM
FS: Complete AMD System cheap 7600gs 512mb agp 6600gt agp Water cooling kits MarcusFoX Buy/Sell & Trade 7 May 17, 2008 12:19 PM
3850 AGP reviewed-yes, AGP Babrbarossa Reviews & Articles from the Web 8 February 19, 2008 02:51 PM
WTB: GeForce 7800 based AGP card & PCI SATA controller MacJunky Buy/Sell & Trade 6 January 16, 2008 06:11 PM
