-   -   Problems with a 4870 (http://www.hardwarecanucks.com/forum/video-cards/18253-problems-4870-a.html)
panzival May 25, 2009 05:47 PM
I just bought a new 4870 and I keep getting constant artifacts and I can't figure out the problem.. I had a 8800 GTS before and I uninstalled the drivers and driver sweeper to clean up anything else remaining. I've tried using both the 9.4 and 9.5 drivers, both acted the same. The temperature is normal, 49 C. Any help would be appreciated.
Nademon May 25, 2009 06:14 PM
Driver sweep from safe mode was done? try cleaning out all the mobo chipset drivers and GPU drivers from safe mode..then reinstall mobo chipset drivers...reboot, then install GPU drivers. Make sure you clean for both ATI and Nvidia drivers while in safe mode. You haven't overclocked the card have you?
sswilson May 25, 2009 06:25 PM
Try pegging the fan speed to 100% to eliminate overheating of the PCB components as a possible snag.
panzival May 25, 2009 06:28 PM
yes i ran it in safe mode and no i havent tried overclocking. my video card wont even display anything now. i tried to run the far cry 2 benchmark and my computer just shutoff. i get no display now when i turn on my pc, but the video card is definetly on. had to write this on my ps3.
edit: ive also noticed that underside of the video card has 3 green lights. no idea what they mean but i assume its good
panzival May 25, 2009 06:29 PM
tried that as well. put it to 100% and left the computer for 20 min. nothing was different.
hossdaddy May 25, 2009 06:45 PM
what psu do you have? make, model and age?
TimTheEnchanter May 25, 2009 06:52 PM
Agree, give more info about the psu... and whole system while you're at it. Both 6 pins connectors are connected?
stoanee May 25, 2009 07:00 PM
There are numbers on the pcb that are associated with those lights, I know that one of them means "critical component overheating" (when red) as in the power regulators and other chips on the card. If you google it you may find out what the other lights are for.
Edit...found this...error lights
DIAGNOSTIC LEDs ON HD4850/70 & HD3/4xxX2 series cards. - VGA Forums
panzival May 25, 2009 07:38 PM
My lights are green so they should be good
Yes I have both 6 pin connectors connected.
Staples
I believe that is my PSU. I can't take out my PSU right now to see the sticker. PSU is about 2 years old. And here's my DXDIAG
System Information
Time of this report: 5/25/2009, 20:38:38
Machine name: TONY-PC
Operating System: Windows 7 Ultimate 32-bit (6.1, Build 7100) (7100.winmain_win7rc.090421-1700)
Language: English (Regional Setting: English)
System Manufacturer: HP-Pavilion
System Model: GC671AAR-ABA a6130n
BIOS: Phoenix - AwardBIOS v6.00PG
Processor: AMD Athlon(tm) 64 X2 Dual Core Processor 5000+ (2 CPUs), ~2.6GHz
Memory: 3072MB RAM
Available OS Memory: 3070MB RAM
Page File: 1215MB used, 4925MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7100.0000 32bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Sound Tab 2: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: ATI Radeon HD 4800 Series
Manufacturer: ATI Technologies Inc.
Chip type: ATI Radeon Graphics Processor (0x9440)
DAC type: Internal DAC(400MHz)
Device Key: Enum\PCI\VEN_1002&DEV_9440&SUBSYS_E850174B&REV_00
Display Memory: 1786 MB
Dedicated Memory: 507 MB
Shared Memory: 1279 MB
Current Mode: 1920 x 1200 (32 bit) (59Hz)
Monitor Name: Generic PnP Monitor
Monitor Model: L2410NM
Monitor Id: WDE5180
Native Mode: 1920 x 1200(p) (59.950Hz)
Output Type: HD15
Driver Name: atiumdag.dll,atidxx32.dll,atidxx64,atiumdva.cap,at iumd64,atiumd6a,atitmm64
Driver File Version: 8.14.0010.0662 (English)
Driver Version: 8.612.0.0
DDI Version: 10.1
Driver Model: WDDM 1.1
Driver Attributes: Final Retail
Driver Date/Size: 4/28/2009 19:52:02, 3082752 bytes
WHQL Logo'd: n/a
WHQL Date Stamp: n/a
Device Identifier: {D7B71EE2-D700-11CF-6D76-5AC8A1C2C535}
Vendor ID: 0x1002
Device ID: 0x9440
SubSys ID: 0xE850174B
Revision ID: 0x0000
Driver Strong Name: oem64.inf:ATI.Mfg.NTx86.6.1:ati2mtag_R7X:8.612.0.0 :pci\ven_1002&dev_9440
Rank Of Driver: 00E62001
Video Accel: ModeMPEG2_A ModeMPEG2_C
Deinterlace Caps: {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{3C5323C1-6FB7-44F5-9081-056BF2EE449D}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{552C0DAD-CCBC-420B-83C8-74943CF9F1A6}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
D3D9 Overlay: Not Supported
DXVA-HD: Not Supported
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
Sound Devices
Description: Speakers (Realtek High Definition Audio)
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0888&SUBSYS_103C2A61& REV_1001
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: RTKVHDA.sys
Driver Version: 6.00.0001.5789 (English)
WHQL Logo'd: n/a
Date and Size: 2/11/2009 12:38:14, 2324512 bytes
Other Files:
Driver Provider: Realtek Semiconductor Corp.
HW Accel Level: Basic
Cap Flags: 0x0
Min/Max Sample Rate: 0, 0
Static/Strm HW Mix Bufs: 0, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Description: Realtek Digital Output (Realtek High Definition Audio)
Default Sound Playback: No
Default Voice Playback: No
Manufacturer ID: 1
Product ID: 100
Type: WDM
WHQL Logo'd: n/a
Other Files:
Cap Flags: 0x0
HW Memory: 0
Sound Capture Devices
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Poll w/ Interrupt: No
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x10DE, 0x03F1
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 4/21/2009 21:50:28, 258048 bytes
| Driver: usbd.sys, 4/21/2009 21:49:30, 5888 bytes
Gameport Devices
PS/2 Devices
+ Enhanced Multimedia PS/2 Keyboard
| Matching Device ID: acpi\pnp0303
| Upper Filters: PS2
| Service: i8042prt
| Driver: PS2.sys, 12/12/2005 11:27:00, 19072 bytes
| Driver: i8042prt.sys, 4/21/2009 21:08:48, 80896 bytes
| Driver: kbdclass.sys, 4/21/2009 23:24:03, 42576 bytes
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
+ PS/2 Compatible Mouse
| Matching Device ID: *pnp0f13
| Service: i8042prt
| Driver: mouclass.sys, 4/21/2009 23:24:02, 41040 bytes
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
| Driver: termdd.sys, 4/21/2009 23:23:47, 51792 bytes
| Driver: sermouse.sys, 4/21/2009 21:43:35, 19968 bytes
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 131.7 GB
Total Space: 372.5 GB
File System: NTFS
Model: WDC WD40 00AAJS-65TKA SCSI Disk Device
Drive: D:
Free Space: 1.0 GB
Total Space: 9.1 GB
File System: NTFS
Drive: E:
Model: HL-DT-ST DVDRRW GSA-H30L SCSI CdRom Device
Driver: c:\windows\system32\drivers\cdrom.sys, 6.01.7100.0000 (English), 4/21/2009 21:08:50, 108544 bytes
System Devices
Name: NVIDIA nForce Serial ATA Controller
Device ID: PCI\VEN_10DE&DEV_03F6&SUBSYS_2A61103C&REV_A2\3&241 1E6FE&1&40
Driver: C:\Windows\system32\DRIVERS\nvstor.sys, 10.06.0000.0015 (English), 4/21/2009 23:24:17, 142416 bytes
Name: NVIDIA nForce PCI System Management
Device ID: PCI\VEN_10DE&DEV_03EB&SUBSYS_2A61103C&REV_A2\3&241 1E6FE&1&09
Driver: C:\Windows\system32\NVCOSMB.DLL, 1.03.0004.0028 (English), 8/20/2008 20:35:00, 122880 bytes
Driver: C:\Windows\system32\nvusmb.exe, 1.03.0016.0001 (English), 8/20/2008 20:35:00, 453152 bytes
Driver: C:\Windows\system32\nvsmb.nvu, 8/19/2008 13:41:00, 2344 bytes
Name: AMD DRAM and HyperTransport(tm) Trace Mode Configuration
Device ID: PCI\VEN_1022&DEV_1102&SUBSYS_00000000&REV_00\3&241 1E6FE&1&C2
Driver: n/a
Name: PCI standard RAM Controller
Device ID: PCI\VEN_10DE&DEV_03F5&SUBSYS_2A61103C&REV_A2\3&241 1E6FE&1&0A
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_03EA&SUBSYS_2A61103C&REV_A1\3&241 1E6FE&1&00
Driver: n/a
Name: AMD Address Map Configuration
Device ID: PCI\VEN_1022&DEV_1101&SUBSYS_00000000&REV_00\3&241 1E6FE&1&C1
Driver: n/a
Name: PCI standard PCI-to-PCI bridge
Device ID: PCI\VEN_10DE&DEV_03F3&SUBSYS_CB8410DE&REV_A1\3&241 1E6FE&1&20
Driver: C:\Windows\system32\DRIVERS\pci.sys, 6.01.7100.0000 (English), 4/21/2009 23:24:17, 153680 bytes
Device ID: PCI\VEN_10DE&DEV_03E9&SUBSYS_000010DE&REV_A2\3&241 1E6FE&1&60
Name: AMD HyperTransport(tm) Configuration
Device ID: PCI\VEN_1022&DEV_1100&SUBSYS_00000000&REV_00\3&241 1E6FE&1&C0
Driver: n/a
Name: Standard Enhanced PCI to USB Host Controller
Device ID: PCI\VEN_10DE&DEV_03F2&SUBSYS_2A61103C&REV_A3\3&241 1E6FE&1&11
Driver: C:\Windows\system32\drivers\usbehci.sys, 6.01.7100.0000 (English), 4/21/2009 21:49:40, 40960 bytes
Driver: C:\Windows\system32\drivers\usbport.sys, 6.01.7100.0000 (English), 4/21/2009 21:49:40, 283136 bytes
Driver: C:\Windows\system32\drivers\usbhub.sys, 6.01.7100.0000 (English), 4/21/2009 21:50:28, 258048 bytes
Device ID: PCI\VEN_10DE&DEV_03E9&SUBSYS_000010DE&REV_A2\3&241 1E6FE&1&58
Name: High Definition Audio Controller
Device ID: PCI\VEN_1002&DEV_AA30&SUBSYS_AA30174B&REV_00\4&301 32929&0&0148
Driver: C:\Windows\system32\DRIVERS\hdaudbus.sys, 6.01.7100.0000 (English), 4/21/2009 21:49:20, 108544 bytes
Name: Standard OpenHCD USB Host Controller
Device ID: PCI\VEN_10DE&DEV_03F1&SUBSYS_2A61103C&REV_A3\3&241 1E6FE&1&10
Driver: C:\Windows\system32\drivers\usbohci.sys, 6.01.7100.0000 (English), 4/21/2009 21:49:39, 20480 bytes
Device ID: PCI\VEN_10DE&DEV_03E8&SUBSYS_000010DE&REV_A2\3&241 1E6FE&1&48
Name: ATI Radeon HD 4800 Series
Device ID: PCI\VEN_1002&DEV_9440&SUBSYS_E850174B&REV_00\4&301 32929&0&0048
Driver: C:\Windows\system32\DRIVERS\atikmdag.sys, 8.01.0001.0899 (English), 4/28/2009 21:31:38, 4491776 bytes
Driver: C:\Windows\system32\DRIVERS\ati2erec.dll, 1.00.0000.0019 (English), 4/28/2009 19:11:00, 53248 bytes
Driver: C:\Windows\system32\atiumdag.dll, 8.14.0010.0662 (English), 4/28/2009 19:52:02, 3082752 bytes
Driver: C:\Windows\system32\atiumdva.dll, 8.14.0010.0223 (English), 4/28/2009 19:37:04, 4963840 bytes
Driver: C:\Windows\system32\atitmmxx.dll, 6.14.0011.0021 (English), 4/28/2009 20:06:26, 159744 bytes
Driver: C:\Windows\system32\atiicdxx.dat, 3/2/2009 14:55:18, 184751 bytes
Driver: C:\Windows\system32\amdpcom32.dll, 8.14.0010.0023 (English), 4/28/2009 19:25:08, 51712 bytes
Driver: C:\Windows\system32\atimpc32.dll, 8.14.0010.0023 (English), 4/28/2009 19:25:08, 51712 bytes
Driver: C:\Windows\system32\atiadlxx.dll, 6.14.0010.1040 (English), 4/28/2009 19:24:34, 163840 bytes
Driver: C:\Windows\system32\atiumdva.cap, 4/28/2009 19:36:36, 167952 bytes
Driver: C:\Windows\system32\atimuixx.dll, 6.14.0010.1001 (English), 4/28/2009 20:05:46, 11776 bytes
Driver: C:\Windows\system32\atiesrxx.exe, 6.14.0011.1025 (English), 4/28/2009 20:07:32, 176128 bytes
Driver: C:\Windows\system32\atieclxx.exe, 6.14.0011.1025 (English), 4/28/2009 20:08:00, 303104 bytes
Driver: C:\Windows\system32\atipdlxx.dll, 6.14.0010.2553 (English), 4/28/2009 20:06:08, 356352 bytes
Driver: C:\Windows\system32\Oemdspif.dll, 6.15.0006.0005 (English), 4/28/2009 20:05:54, 278528 bytes
Driver: C:\Windows\system32\ati2edxx.dll, 6.14.0010.2514 (English), 4/28/2009 20:05:38, 43520 bytes
Driver: C:\Windows\system32\ATIDEMGX.dll, 2.00.3405.38053 (English), 4/28/2009 20:08:28, 442368 bytes
Driver: C:\Windows\system32\atioglxx.dll, 6.14.0010.8664 (English), 4/28/2009 19:41:56, 11559424 bytes
Driver: C:\Windows\system32\aticaldd.dll, 6.14.0010.0283 (English), 4/28/2009 19:20:58, 3293184 bytes
Driver: C:\Windows\system32\aticalrt.dll, 6.14.0010.0283 (English), 4/28/2009 19:22:20, 53248 bytes
Driver: C:\Windows\system32\aticalcl.dll, 6.14.0010.0283 (English), 4/28/2009 19:22:04, 53248 bytes
Driver: C:\Windows\system32\atibtmon.exe, 2.00.0000.0000 (English), 3/3/2009 13:56:00, 118784 bytes
Driver: C:\Windows\system32\atidxx32.dll, 8.15.0010.0198 (English), 4/28/2009 20:02:54, 2428928 bytes
Driver: C:\Windows\atiogl.xml, 2/25/2009 02:42:06, 16032 bytes
Driver: C:\Windows\system32\ATIODCLI.exe, 1.00.0000.0001 (English), 2/3/2009 14:52:02, 45056 bytes
Driver: C:\Windows\system32\ATIODE.exe, 1.00.0000.0001 (English), 2/18/2009 11:55:20, 294912 bytes
Device ID: PCI\VEN_10DE&DEV_03F0&SUBSYS_2A61103C&REV_A2\3&241 1E6FE&1&28
Name: PCI standard ISA bridge
Device ID: PCI\VEN_10DE&DEV_03E0&SUBSYS_2A61103C&REV_A2\3&241 1E6FE&1&08
Driver: C:\Windows\system32\DRIVERS\msisadrv.sys, 6.01.7100.0000 (English), 4/21/2009 23:23:53, 13904 bytes
Name: VIA 1394 OHCI Compliant Host Controller
Device ID: PCI\VEN_1106&DEV_3044&SUBSYS_2A61103C&REV_80\4&941 8CF&0&4820
Driver: C:\Windows\system32\DRIVERS\1394ohci.sys, 6.01.7100.0000 (English), 4/21/2009 21:50:20, 162816 bytes
Name: NVIDIA nForce 10/100 Mbps Ethernet
Device ID: PCI\VEN_10DE&DEV_03EF&SUBSYS_2A61103C&REV_A2\3&241 1E6FE&1&38
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_03F6&SUBSYS_2A61103C&REV_A2\3&241 1E6FE&1&41
Name: Standard Dual Channel PCI IDE Controller
Device ID: PCI\VEN_10DE&DEV_03EC&SUBSYS_2A61103C&REV_A2\3&241 1E6FE&1&30
Driver: C:\Windows\system32\DRIVERS\pciide.sys, 6.01.7100.0000 (English), 4/21/2009 23:23:53, 12368 bytes
Driver: C:\Windows\system32\DRIVERS\pciidex.sys, 6.01.7100.0000 (English), 4/21/2009 23:24:04, 42576 bytes
Driver: C:\Windows\system32\DRIVERS\atapi.sys, 6.01.7100.0000 (English), 4/21/2009 23:24:04, 21584 bytes
Driver: C:\Windows\system32\DRIVERS\ataport.sys, 6.01.7100.0000 (English), 4/21/2009 23:24:21, 133200 bytes
Name: AMD Miscellaneous Configuration
Device ID: PCI\VEN_1022&DEV_1103&SUBSYS_00000000&REV_00\3&241 1E6FE&1&C3
Driver: n/a
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,WMADMOD.DLL,6.01.7100.0000
WMAPro over S/PDIF DMO,0x00600800,1,1,WMADMOD.DLL,6.01.7100.0000
WMSpeech Decoder DMO,0x00600800,1,1,WMSPDMOD.DLL,6.01.7100.0000
MP3 Decoder DMO,0x00600800,1,1,mp3dmod.dll,6.01.7100.0000
Mpeg4s Decoder DMO,0x00800001,1,1,mp4sdecd.dll,6.01.7100.0000
WMV Screen decoder DMO,0x00600800,1,1,wmvsdecd.dll,6.01.7100.0000
WMVideo Decoder DMO,0x00800001,1,1,wmvdecod.dll,6.01.7100.0000
Mpeg43 Decoder DMO,0x00800001,1,1,mp43decd.dll,6.01.7100.0000
Mpeg4 Decoder DMO,0x00800001,1,1,mpg4decd.dll,6.01.7100.0000
Annodex Mux Filter,0x00200000,1,0,dsfAnxMux.dll,0.79.1936.0000
CMML Decode Filter,0x00800002,1,1,dsfCMMLDecoder.dll,0.79.1936 .0000
CMML Raw Source Filter,0x00600000,0,0,dsfCMMLRawSource.dll,0.79.19 36.0000
FLAC Decode Filter,0x00600000,1,1,dsfFLACDecoder.dll,0.79.1936 .0000
FLAC Encode Filter,0x00200000,1,1,dsfFLACEncoder.dll,0.79.1936 .0000
Native FLAC Source Filter,0x00600000,0,0,dsfNativeFLACSource.dll,0.79 .1936.0000
Ogg Demux Packet Source Filter,0x00600000,0,0,dsfOggDemux2.dll,0.79.1936.0 000
Ogg Mux Filter,0x00200000,1,0,dsfOggMux.dll,0.79.1936.0000
OGM Decode Filter,0x00600000,1,1,dsfOGMDecoder.dll,0.79.1936. 0000
Speex Decode Filter,0x00600000,1,1,dsfSpeexDecoder.dll,0.79.193 6.0000
Speex Encode Filter,0x00200000,1,1,dsfSpeexEncoder.dll,0.79.193 6.0000
Subtitle VMR9 Filter,0x00800002,1,1,dsfSubtitleVMR9.dll,0.79.193 6.0000
Theora Decode Filter,0x00600000,1,1,dsfTheoraDecoder.dll,0.79.19 36.0000
Theora Encode Filter,0x00200000,1,1,dsfTheoraEncoder.dll,0.79.19 36.0000
Vorbis Decode Filter,0x00600000,1,1,dsfVorbisDecoder.dll,0.79.19 36.0000
Vorbis Encode Filter,0x00200000,1,1,dsfVorbisEncoder.dll,0.79.19 36.0000
Roxio Vob Loader,0x00200000,0,1,VOBLoader.ax,9.00.0005.0079
ROXIO VCFLatency 3.0,0x00200000,1,1,latency.ax,9.00.0005.0080
ROXIO VCFWaveform 1.0,0x00200000,1,0,waveform.ax,9.00.0005.0080
ROXIO SceneRecorder 1.0,0x00200000,1,0,SceneRecorderFilt.ax,9.00.0005. 0080
ROXIO Image/Colour Source 3.0,0x00200000,0,1,ImageSource.ax,9.00.0005.0080
roxio DCFilters Dragon Lair,0x00200000,0,1,DCFilters9.dll,9.00.0005.0077
MainConcept (Sonic) DV Video Decoder,0x00600000,1,1,sonicmcdsdv.ax,2.01.0000.00 04
MainConcept (Sonic) DV Video Encoder,0x00200000,1,1,sonicmcdsdv.ax,2.01.0000.00 04
roxio DCFilters Subpicture Mixer,0x00200000,2,1,DCFilters9.dll,9.00.0005.0077
ATI Ticker,0x00200000,0,1,Ticker.ax,
DV Muxer,0x00400000,0,0,qdv.dll,6.06.7100.0000
ROXIO AudioGrabber 3.0,0x00200000,1,0,thumbnailgraber.ax,9.00.0005.00 80
roxio DCFilters Mpeg I/II Decoder,0x00200000,1,1,DCFilters9.dll,9.00.0005.00 77
ROXIO VideoCombine 3.0,0x00200000,1,0,VideoCombine.ax,9.00.0005.0080
Roxio Smart Decoder,0x00200000,1,1,MPEG2VidCodec.dll,9.00.0005 .0079
Roxio Transport Stream Source,0x00200000,0,1,TSMPEGSource.dll,9.00.0005.0 079
Color Space Converter,0x00400001,1,1,quartz.dll,6.06.7100.0000
WM ASF Reader,0x00400000,0,0,qasf.dll,12.00.7100.0000
ROXIO AudioConvert 3.0,0x00200000,1,1,audconv.ax,9.00.0005.0080
ROXIO WAV Dest 3.0,0x00200000,0,0,WavHead.ax,9.00.0005.0080
Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,12.00.7100.0000
Roxio Audio Stream Reader Filter,0x00200000,1,0,RxDSAudioStreamWriter.ax,1.0 0.0000.0001
AVI Splitter,0x00600000,1,1,quartz.dll,6.06.7100.0000
Roxio Repacketizer Filter,0x00200000,1,1,RepackFilter.dll,9.00.0005.0 079
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.06.7100.0000
ROXIO SubPicture Encoder,0x00200000,1,1,SubPictEnc.dll,9.00.0005.00 79
SBE2MediaTypeProfile,0x00200000,0,0,sbe.dll,6.06.7 100.0000
Microsoft DTV-DVD Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,6.01.7075.0 000
ROXIO Audio VCFLooper 3.0,0x00200000,1,1,Looper.ax,9.00.0005.0080
Roxio MPEG2 Video Decoder,0x00200000,1,1,MPEG2VidCodec.dll,9.00.0005 .0079
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.06.7100.0000
ROXIO VCFpeakmeter 3.0,0x00200000,1,1,peakmeter.ax,9.00.0005.0080
Roxio MPEG1 Encoder,0x00200000,1,1,MPEG1VidCodec.dll,9.00.0005 .0079
ROXIO DVDCrossGraphEx Source 3.0,0x00200000,0,1,DVDCrossGraphEx.ax,9.00.0005.00 80
StreamBufferSink,0x00200000,0,0,sbe.dll,6.06.7100. 0000
Microsoft TV Captions Decoder,0x00200001,1,0,MSTVCapn.dll,6.01.7100.0000
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.06.7100.0 000
ROXIO VCFDVSceneDetect 1.0,0x00200000,1,2,DVSceneDetectFilt.ax,9.00.0005. 0080
DivX for Blizzard Decoder Filter,0x00800000,1,1,blizzard.ax,
Roxio VOB Formatter,0x00200000,1,1,VOBFormatter.ax,9.00.0005 .0079
CBVA DMO wrapper filter,0x00200000,1,1,cbva.dll,6.01.7100.0000
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.06.7100.0000
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.06.7100.0000
VBI Codec,0x00600000,1,4,VBICodec.ax,6.06.7100.0000
ROXIO ColorSpace Converter 3.0,0x00200000,1,1,ColorSpConv.dll,9.00.0005.0080
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.06.7100.0000
Closed Captions Analysis Filter,0x00200000,2,5,cca.dll,6.06.7100.0000
muvee HXImage Filter,0x00200000,1,1,HXImageFilter.ax,6.00.0015.0 003
SBE2FileScan,0x00200000,0,0,sbe.dll,6.06.7100.0000
ROXIO Audio Source 3.0,0x00200000,0,1,AudioSrc.ax,9.00.0005.0080
MediaWriter Filter,0x00200000,1,0,MediaWriter.ax,6.00.0015.000 3
ROXIO DVDCrossGraphEx Renderer 3.0,0x00200000,1,0,DVDCrossGraphEx.ax,9.00.0005.00 80
Microsoft MPEG-2 Video Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7100.00 00
ROXIO Pin Tee,0x00200000,1,1,RoxioInfTee.ax,
ROXIO QuickGrabber 3.0,0x00200000,1,0,thumbnailgraber.ax,9.00.0005.00 80
Roxio Audio Source Filter,0x00400000,0,1,RxDSAudioSource.ax,9.00.0000 .0000
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.06.7100.0000
Roxio MPEG Stream Analyzer,0x00200000,1,2,MPEGStreamAnalyzer.dll,9.0 0.0005.0079
Sonic MPEG-2 Video Decoder,0x00200000,2,2,sonicm2vd.ax,1.00.0197.6032 2
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.06.7100.0000
MMACE ProcAmp,0x00200000,0,2,MMACEFilters.dll,
ROXIO CrossGraphEx Source 3.0,0x00200000,0,1,CrossGraphEx.ax,9.00.0005.0080
Roxio MPEG2 Encoder,0x00200000,1,1,MPEG2VidCodec.dll,9.00.0005 .0079
ROXIO VCFDvrSupport 3.0,0x00200000,1,1,DvrSupportFilt.ax,9.00.0005.008 0
DV Splitter,0x00600000,1,2,qdv.dll,6.06.7100.0000
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.06.7100.0000
ROXIO LPCMSyncFilter,0x00200000,1,1,LPCMSyncFilter.dll,9 .00.0005.0079
ROXIO Audio VCFChunker 3.0,0x00200000,1,1,Chunker.ax,9.00.0005.0080
ROXIO Pan Zoom 3.0,0x00200000,1,1,PanZoom.ax,9.00.0005.0080
VCG Null Renderer 3.0,0x00200000,1,0,VideoCompositing.ax,
Roxio Audio Stream Reader Filter,0x00200000,1,0,RxDSAudioStreamReader.ax,9.0 0.0000.0000
Roxio Smart Encoder,0x00200000,2,1,MPEG2VidCodec.dll,9.00.0005 .0079
Roxio Plasma CrossGraph Source,0x00200000,0,1,PlasmaCGFilter.ax,9.00.0005. 0079
muvee ScrambleReader Filter,0x00200000,0,1,mvScrambleReader.ax,8.01.000 0.0000
ROXIO InputSelector 3.0,0x00200000,1,0,InputSelector.ax,9.00.0005.0080
Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,6.01.7100.00 00
ROXIO ThumbnailGrabber 3.0,0x00200000,1,0,thumbnailgraber.ax,9.00.0005.00 80
ACM Wrapper,0x00600000,1,1,quartz.dll,6.06.7100.0000
ROXIO VCFVideoCutList 3.0,0x00200000,1,1,vCutList.ax,9.00.0005.0080
Video Renderer,0x00800001,1,0,quartz.dll,6.06.7100.0000
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.06.7100.0000
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.06.7100.0000
Video Port Manager,0x00600000,2,1,quartz.dll,6.06.7100.0000
Video Renderer,0x00400000,1,0,quartz.dll,6.06.7100.0000
ROXIO Deinterlace 3.0,0x00200000,1,1,DeInter.ax,9.00.0005.0080
QuickTimeRenderer Filter,0x00200000,1,0,QuickTimeRenderer.ax,8.01.00 00.0000
Sonic MPEG Audio Decoder,0x00200000,1,1,sonicdsmpeg.ax,1.01.3858.00 00
Sonic MPEG Video Decoder,0x00200000,1,1,sonicdsmpeg.ax,1.01.3858.00 00
ROXIO ListImage Source 3.0,0x00200000,0,1,ListImageSource.ax,9.00.0005.00 80
VPS Decoder,0x00200000,0,0,WSTPager.ax,6.06.7100.0000
WM ASF Writer,0x00400000,0,0,qasf.dll,12.00.7100.0000
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,6.01.7100.0000
ROXIO Video VCFLooper 3.0,0x00200000,1,1,vlooper.ax,9.00.0005.0080
MMACE SoftEmu,0x00200000,0,2,MMACEFilters.dll,
File writer,0x00200000,1,0,qcap.dll,6.06.7100.0000
Roxio Plasma CrossGraph Renderer,0x00200000,1,0,PlasmaCGFilter.ax,9.00.000 5.0079
VMR9 Wrapper 3.0,0x00200000,1,0,VideoCompositing.ax,
iTV Data Sink,0x00600000,1,0,itvdata.dll,6.06.7100.0000
iTV Data Capture filter,0x00600000,1,1,itvdata.dll,6.06.7100.0000
ROXIO SpyPos 3.0,0x00200000,1,1,MGINullIP.ax,9.00.0005.0080
roxio DCFilters Smart Resizer,0x00200000,1,1,DCFilters9.dll,9.00.0005.00 77
ROXIO QT Source,0x00200000,0,1,QTSource.ax,9.00.0005.0080
ROXIO Sewer 3.0,0x00200000,1,0,MVWcDSutil.dll,9.00.0005.0080
Roxio MPEG1 Muxer,0x00200000,2,1,MPEG1Muxer.dll,9.00.0005.0079
ROXIO VCFAudioMixer 3.0,0x00200000,1,1,audmf.ax,9.00.0005.0080
ROXIO CrossGraphEx Renderer 3.0,0x00200000,1,0,CrossGraphEx.ax,9.00.0005.0080
DVD Navigator,0x00200000,0,3,qdvd.dll,6.06.7100.0000
ROXIO InputSelectorNew 3.0,0x00200000,1,0,InputSelector.ax,9.00.0005.0080
MMACE DeInterlace,0x00200000,0,2,MMACEFilters.dll,
Microsoft TV Subtitles Decoder,0x00200001,1,0,MSTVCapn.dll,6.01.7100.0000
Overlay Mixer2,0x00200000,1,1,qdvd.dll,6.06.7100.0000
mvAudioScope,0x00200000,1,0,mvAudioScope.ax,6.00.0 015.0003
AVI Draw,0x00600064,9,1,quartz.dll,6.06.7100.0000
muvee Video Analyser,0x00200000,1,0,mvvanalyse.ax,6.00.0015.00 00
muvee Music Analyser,0x00200000,1,0,mvmanalyse.ax,6.00.0015.00 00
MainConcept (Muvee) MPEG Splitter,0x00400001,1,2,muveespmpeg.ax,1.00.0001.0 012
MainConcept (Muvee) MPEG Audio Decoder,0x00400001,1,1,muveedsmpeg.ax,1.00.0000.00 77
MainConcept (Muvee) MPEG Video Decoder,0x00400001,1,1,muveedsmpeg.ax,1.00.0000.00 77
MainConcept (Muvee) MPEG Audio Encoder,0x00200000,1,1,muveeeampeg.ax,1.01.0000.00 03
RDP DShow Redirection Filter,0xffffffff,1,0,DShowRdpFilter.dll,
Microsoft MPEG-2 Audio Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7100.00 00
WST Pager,0x00200000,1,1,WSTPager.ax,6.06.7100.0000
ROXIO LVM File Source (Async.),0x00200000,0,1,LVMAsync.ax,9.00.0005.0079
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.06.7100 .0000
DV Video Decoder,0x00800000,1,1,qdv.dll,6.06.7100.0000
LVMWriter,0x00200000,1,0,LVMWriter.ax,9.00.0005.00 79
Roxio Mp3 Encoder (SC),0x00600000,1,1,RxDSMp3Encoder.ax,1.00.0000.00 01
VCG Video Mixer 3.0,0x00200000,0,1,VideoCompositing.ax,
MainConcept (Muvee) MPEG-2 Video Decoder,0x005ffffe,2,2,muveem2vd.ax,1.01.0000.9816
QuickTime Source Filter,0x00200000,0,1,QuickTimeSource.dll,6.00.001 5.0003
SampleGrabber,0x00200000,1,1,qedit.dll,6.06.7100.0 000
Null Renderer,0x00200000,1,0,qedit.dll,6.06.7100.0000
MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,6.06.7100.0000
Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,6.01.7100.0000
Roxio MPEG Analyzer,0x00200000,1,0,RoxioMPEGProp.dll,9.00.000 5.0079
StreamBufferSource,0x00200000,0,0,sbe.dll,6.06.710 0.0000
roxio DCFilters DVD Reader,0x00200000,0,1,DCFilters9.dll,9.00.0005.007 7
Smart Tee,0x00200000,1,2,qcap.dll,6.06.7100.0000
ROXIO MPEG Writer,0x00200000,1,0,MGIRawWriter.dll,9.00.0005.0 079
Roxio MPEG2 Muxer,0x00200000,4,0,MPEG2Muxer.dll,9.00.0005.0079
VCGImageSource,0x00200000,0,1,VideoCompositing.ax,
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.06.7100.0000
AVI Decompressor,0x00600000,1,1,quartz.dll,6.06.7100.0 000
roxio DCFilters DVD Splitter,0x00200000,1,3,DCFilters9.dll,9.00.0005.0 077
NetBridge,0x00200000,2,0,netbridge.dll,6.01.7100.0 000
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.06.7100.0000
Wave Parser,0x00400000,1,1,quartz.dll,6.06.7100.0000
MIDI Parser,0x00400000,1,1,quartz.dll,6.06.7100.0000
Multi-file Parser,0x00400000,1,1,quartz.dll,6.06.7100.0000
File stream renderer,0x00400000,1,1,quartz.dll,6.06.7100.0000
PSI Parser,0x00200000,0,0,PsiParser.ax,
roxio DCFilters Audio Sync Filter 2,0x00200000,1,1,DCFilters9.dll,9.00.0005.0077
Media Analyser,0x00200000,1,2,mediaanalyser.ax,9.00.0005 .0080
Microsoft DTV-DVD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,6.01.7075.0 000
StreamBufferSink2,0x00200000,0,0,sbe.dll,6.06.7100 .0000
AVI Mux,0x00200000,1,0,qcap.dll,6.06.7100.0000
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.06.7100.0000
File Source (Async.),0x00400000,0,1,quartz.dll,6.06.7100.0000
File Source (URL),0x00400000,0,1,quartz.dll,6.06.7100.0000
Media Center Extender Encryption Filter,0x00200000,2,2,Mcx2Filter.dll,6.01.7100.000 0
Roxio MPEG1 Audio Encoder,0x00200000,1,1,RoxioAudioEnc.dll,9.00.0005 .0079
roxio DCFilters DVD Muxer,0x00200000,1,1,DCFilters9.dll,9.00.0005.0077
AudioRecorder WAV Dest,0x00200000,0,0,WavDest.dll,
AudioRecorder Wave Form,0x00200000,0,0,WavDest.dll,
SoundRecorder Null Renderer,0x00200000,0,0,WavDest.dll,
QuickTime Encoder,0x00200000,1,0,QuickTimeSink.ax,6.00.0015. 0003
ROXIO Scene Detector 3.0,0x00200000,1,1,SceneDetector.ax,9.00.0005.0080
ROXIO Simple Dump 3.0,0x00200000,1,0,RxSimpleDump.ax,9.00.0005.0080
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.06.7100.0000
Roxio Audio Decoder (DVD),0x00200000,1,1,RoxioDVDAudio.dll,9.00.0005.0 079
ROXIO Video Resampler 3.0,0x00200000,1,1,VResamFilt.ax,9.00.0005.0080
Enhanced Video Renderer,0x00200000,1,0,evr.dll,6.01.7100.0000
Roxio MPEG2 Demuxer,0x00600000,1,2,RoxioMPEGDemuxer.dll,9.00.0 005.0079
BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,6.06.7100.0000
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.06.7100.0000
WDM Streaming Tee/Splitter Devices:
Tee/Sink-to-Sink Converter,0x00200000,1,1,ksproxy.ax,6.01.7100.0000
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,wmvxencd.dll,6.01.7100.0000
WMVideo9 Encoder DMO,0x00600800,1,1,wmvencod.dll,6.01.7100.0000
MSScreen 9 encoder DMO,0x00600800,1,1,wmvsencd.dll,6.01.7100.0000
DV Video Encoder,0x00200000,0,0,qdv.dll,6.06.7100.0000
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.06.7100.000 0
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.06.7100.0000
Intel IYUV codec,0x00200000,1,1,qcap.dll,6.06.7100.0000
Microsoft RLE,0x00200000,1,1,qcap.dll,6.06.7100.0000
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.06.7100.0000
VP60 Simple Profile ,0x00200000,1,1,qcap.dll,6.06.7100.0000
VP61 Advanced Profile,0x00200000,1,1,qcap.dll,6.06.7100.0000
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,WMSPDMOE.DLL,6.01.7100.0000
WMAudio Encoder DMO,0x00600800,1,1,WMADMOE.DLL,6.01.7100.0000
IMA ADPCM,0x00200000,1,1,quartz.dll,6.06.7100.0000
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.06.7100.0000
GSM 6.10,0x00200000,1,1,quartz.dll,6.06.7100.0000
CCITT A-Law,0x00200000,1,1,quartz.dll,6.06.7100.0000
CCITT u-Law,0x00200000,1,1,quartz.dll,6.06.7100.0000
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.06.7100.0000
PBDA CP Filters:
PBDA DTFilter,0x00600000,1,1,CPFilters.dll,6.06.7100.00 00
PBDA ETFilter,0x00200000,0,0,CPFilters.dll,6.06.7100.00 00
PBDA PTFilter,0x00200000,0,0,CPFilters.dll,6.06.7100.00 00
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.06.7100.0000
Microsoft GS Wavetable Synth,0x00200000,1,0,quartz.dll,6.06.7100.0000
WDM Streaming Capture Devices:
,0x00000000,0,0,,
,0x00000000,0,0,,
,0x00000000,0,0,,
,0x00000000,0,0,,
WDM Streaming Rendering Devices:
ATI HD Audio rear output,0x00200000,1,1,ksproxy.ax,6.01.7100.0000
Realtek HD Audio rear output,0x00200000,1,1,ksproxy.ax,6.01.7100.0000
Realtek HDA SPDIF Out,0x00200000,1,1,ksproxy.ax,6.01.7100.0000
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7100.0000
Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7100.0000
Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7100.0000
Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7100.0000
Microsoft Network Provider,0x00200000,0,1,MSNP.ax,6.06.7100.0000
Multi-Instance Capable VBI Codecs:
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,6.06.7100.0000
MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,6.06.7100.0000
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,1,EncDec.dll,6.06.7100.0000
Encrypt/Tag,0x00200000,0,0,EncDec.dll,6.06.7100.0000
PTFilter,0x00200000,0,0,EncDec.dll,6.06.7100.0000
XDS Codec,0x00200000,0,0,EncDec.dll,6.06.7100.0000
WDM Streaming Communication Transforms:
Audio Renderers:
Speakers (Realtek High Definiti,0x00200000,1,0,quartz.dll,6.06.7100.0000
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.06.7100.0000
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.06.7100.0000
DirectSound: Realtek Digital Output (Realtek High Definition Audio),0x00200000,1,0,quartz.dll,6.06.7100.0000
DirectSound: Speakers (Realtek High Definition Audio),0x00200000,1,0,quartz.dll,6.06.7100.0000
Realtek Digital Output (Realtek,0x00200000,1,0,quartz.dll,6.06.7100.0000
EVR Power Information
Current Setting: {5C67A112-A4C9-483F-B4A7-1D473BECAFDC} (Quality)
Quality Flags: 2576
Enabled:
Force throttling
Allow half deinterlace
Allow scaling
Decode Power Usage: 100
Balanced Flags: 1424
Enabled:
Force throttling
Allow batching
Force half deinterlace
Force scaling
Decode Power Usage: 50
PowerFlags: 1424
Enabled:
Force throttling
Allow batching
Force scaling
Decode Power Usage: 0
tomek May 25, 2009 08:15 PM
Could it be to do w/ the fact the Windows 7 Ultimate 32-bit is not out yet?
