  #21 (permalink)
Old May 26, 2009, 01:27 PM
Originally Posted by Pelt View Post
One last thing Panzival, please let us know what worked to fix your problem. When folks stop by the site it's usually because they are troubleshooting a problem and they might have one similar to your's, so it would be nice to know if the suggestions provided worked or not.
Don't think you'll see a solution :(. I bought a Rocketfish PSU from futureshop, just to test (I can just return it) out if my PSU is the problem. Turns out the PSU won't fit in the case, so I've just decided to upgrade basically everything. I've been trying to upgrade this crappy HP pc I got 2 years ago but it was already very small inside as is. The 4870 barely fit in.
  #22 (permalink)
Old May 26, 2009, 01:58 PM
thenewguy001's Avatar
You can test the PSU even if it doesn't fit in the case. You can at least see if the PSU is the cause of the problems. But you're buying a whole new system instead?
i5 2500K @ 4.0 GHz
2 x 4GB G.Skill Ripjaws X
Patriot Pyro 240GB
Gigabyte HD 6970 OC
Gigabyte Z68X-UDH3-B3
Seasonic 760W
Coolermaster Hyper 212+
CM690 w/ 1-80mm, 6-120mm fans.
  #23 (permalink)
Old May 26, 2009, 02:26 PM
Can't test it outside either :P The 4 pin connector for the motherboard doesn't fit because the PSU I got has 2 4 pin connectors right beside each other. And I'm not buying a whole new system :P Gonna use parts from my old system. Only new things I'm gonna get is a bigger case, motherboard, cpu and psu.
  #24 (permalink)
Old May 26, 2009, 04:03 PM
+1 psu
get rid of that thing fast. An antec 500 watt earthwatts is plenty for 1 single 4870, and can be had for $70 after taxes.
NCIX's anniversary sale is going on, $107 for a TX650 ATM, which will eat a 4870 crossfire alive if you choose to xfire down the road.
even if the problem isnt your psu, get a new one.
4870 1gb vs 4870 2gb MrFoxx Video Cards 28 May 11, 2009 07:07 AM
4870 512Mb VS 4870 1Gb ddude27 Video Cards 4 April 30, 2009 12:57 AM
[FS] Diamond 4870, XSPC Razor 4870 Block SugarJ Buy/Sell & Trade 4 March 26, 2009 02:26 PM
Video upgrade - 4870 1GB vs 4870 X2 Maplicito New Builds 10 February 24, 2009 12:40 PM
Radeon 4870 Video Display Problems magixx Troubleshooting 2 October 3, 2008 12:54 PM
