-   -   PhysX card for folding (http://www.hardwarecanucks.com/forum/video-cards/17763-physx-card-folding.html)
hertz9753 May 9, 2009 09:02 PM
I have GTX260 and I was wondering if adding a 8800gt PhysX card would help with folding? This is on a non SLI Asus P5Q-E board. Using Vista 32
3.0charlie May 10, 2009 07:42 AM
The 8 and GTX2xx series don't play nice together. I'd wait for LCB001 to see this thread (or even send him a PM), he knows all about this.
LCB001 May 10, 2009 05:35 PM
3.0charlie is correct, unless the new drivers have fixed this mixing 2xx series cards with anything older dosn't work you get nothing but EUE's. And unless you want to deal with the Shader Bug, the only card you can mix with a 260 is another 260 with the same # of shaders.
BTW the new 250 does not count as it's just a rebadged 9800GTX+, not based on the new 200 series architecture...
zlojack May 10, 2009 05:40 PM
It just plain didn't work for me.
I tried MANY different drivers/configs/options and it is a no-go.
10e May 11, 2009 01:08 PM
Funny enough I've had more success getting a GTX 2xx card folding in the same box with a 4850/4870 or 4890 than with a G8x or G9x nVidia board. You should be able to use the 8800/9800GT for PhysX but not folding in the same box.
As for shaders, the only rule to follow is to have two cards with the same shader/stream count, or one that divides directly into another like a 32 or 64 shader with a 128 shader card, otherwise performance suffers for the card with fewer shaders.
hertz9753 May 11, 2009 06:33 PM
Thanks guys. So no G92 chips with the 260 for folding. Wold it still work for Phys X for gaming?
Sagath May 11, 2009 06:48 PM
Yes. The 'shader' bug more of a limitation with F@H then a problem of nVidia's
TimTheEnchanter May 11, 2009 10:08 PM
Don't wanna start a new thread... so here :
i know we can mix ati and nvidia for physx. Is it possible to do it on a P5Q pro? A 4870 as my main gpu and a 8600gt for folding... google search didn't help me.
dhoshaw May 12, 2009 07:35 PM
Would an 8800GT work with a 9800x2?
