Old May 3, 2009, 09:30 AM
How to turn on vsync? I never heard of this before~
And what cause the screen tearing?
Old May 3, 2009, 10:27 AM
Cowboy's Avatar
Vertical sync (or vsync for short) is an extra setting that you can turn on that caps your framerate to be equal to your monitor's refresh rate (for 60hz = 60 fps, get it?)
more info here: Adventures in High Fidelity: Screen Tearing Explained
if its not available as an in-game setting, try enabling it (forcing it) through your nvidia control panel.
Old May 3, 2009, 10:28 AM
aviduser's Avatar
EDIT: Cowboy beat me to it.
I5 4670K 4.4ghz - Gtx 780 Amp - 2x4 Corsair Vengeance - MSI z87-g43 - Tx 850w - Asus pbq278q
Old May 3, 2009, 10:36 AM
Cowboy's Avatar
didn't mean to steal your thunder friend...
I'm just a bit quicker on the draw thats all
Old May 3, 2009, 11:18 AM
BrokenHalo83's Avatar
Originally Posted by C_O_N View Post
Too bad my mobo don't support Phenom II.... but some people with the same mobo has a Phenom II running
So i don't really know if my mobo 100%support Phenom II XD
Your board doesnt officially support Phenom II's but it does support the first phenom chips which would be a bit of an improvemen on what your using now.
Official support list for your motherboard can found through this page, just select from the drop down menu. Also tells you what bios is needed to use these as well
EDIT: you should also remember that the M2N-E doesnt support HT3.0 so you wont be getting the full potential out of a phenom
Old May 3, 2009, 11:30 AM
IRQ Conflict's Avatar
I may be slow on the draw pilgrim, but ma link is better than yers. VSYNC
Edit: Damn, I am slow.
Old May 3, 2009, 06:59 PM
Silvgearx's Avatar
hi, its not bottling that much. Since your playing on 1440x900
for budget gamers, it is recommend to turn off all other applications to increase FPS
I have had a E2180 @ 2.66 with an 8800gt @ 700/975/2000 on 1680x1050 and i almost see no bottle necks.
at 1280x1024 resolutions even an 9600gt would beat a 9800gt or 9800gtx+ and the gtx 285 will be par with the 9600gt at low resolutions. The higher end gpu will only show its true colors in higher resolution game plays.
as your gpu is at 2.0ghz and a 9800gtx w/ 1440x900 you should be fine. If you really want the extra 10FPS or so try overclocking it to 2.5ghz. your cpu should be able to do it with stock volts.
i compared a E8400 @ 3.6ghz and E2180 @ 2.66 it only gave me an average of 4-9 FPS difference. on some games they are almost par
BottleNecking? Chromey Video Cards 10 April 6, 2009 05:36 PM
Sundin signs with Canucks Eldonko Hockey 39 March 18, 2009 03:10 PM
Lecavalier signs with Lightning:11years/$85Mil 1Tanker Hockey 5 July 16, 2008 09:03 AM
What do you suppose is bottlenecking this PC? LookAQuesadilla Troubleshooting 14 April 30, 2007 09:16 AM
