Old April 26, 2009, 09:57 PM
FiveNines's Avatar
Default GPU for the old school
I am building a budget gaming system (AMD 939 socket) and got myself a DFI Ultra-D Lanparty motherboard.
I know of some newer cards that are backwards compatible with PCI-E 1.0. For example the 8800 series. But...
I plan on building a better machine when I have the funds, so should I get a dual duty card, as it were, that will work with my old school setup as well as a better machine should I upgrade? Or just fluff the wasted cash, sell the slower setup when I upgrade and get a new one when the time comes?
VCC Feedback
Old April 27, 2009, 05:05 AM
IRQ Conflict's Avatar
As far as I know all PCIe 2.0 cards are backward compatible. So the choice is really yours.
Whats powering the graphics side of things in it right now?
Old April 27, 2009, 09:00 AM
I agree with IRQ, I was running a 9800gtx+ pcie 2.0 in a mobo with pcie 1.0 everything seemed to be fine. The big question is what's u'r current parts ie cpu single or dual core, mhz?, gpu, monitor and res, what games are u shooting for?
Gaming FX 8350 stock / Tuniq Tower 120/ MSI GTX 1070 Armor / G Skill 32GB / S12D 850w/ GA 990FXA-UD3 /SSD 240GB , WD1TB FALS, 3TB Toshiba / Dell IPS 1920x1080/ Win 10 64
Daily Use x4 965BE 3.6GHZ/GA 970 Gaming/ R7 265 1GB /EA750w/4x4GB ram/Win 10 64 and 24TB of hdds
Old April 27, 2009, 09:45 AM
FiveNines's Avatar
Hold your laughter, an ATI X1300
Athlon X2 Dual Core 4600+ @ 2.4GHz
19" Monitor @ 1280x1024, but I would like to get a larger monitor in the future as I watch quite a bit of video on my computer. Let's say a 22" or 24" widescreen.
As for games, I play a lot of the Source engine, COD4, and recently Demigod.
VCC Feedback
Old April 27, 2009, 10:59 AM
Oversized Rooster's Avatar
Go and pick up a 1GB 4890 video card. You can have fun today, and also tomorrow once you upgrade your PC. It will work just fine with PCI-E 1.0.
Machine: Intel 6800K | Asus X99-E | 32GB Corsair DDR4-2666 | 500GB Samsung 960 EVO NVMe | 6TB WD Black | 2 x 4TB Hitachi 7K4000 | Corsair 750D | Seasonic XP-860 Platinum | 4GB GTX 970 G1 Windforce | 2 x 27" Samsung S27D390HS PLS | Win10 Pro 64-bit
Old April 27, 2009, 12:11 PM
also keep in mind which PSU are you using? if its an older 400-500 watt then you might be in trouble with something like a 4890
Old April 27, 2009, 01:39 PM
JD JD is offline
I wouldn't buy a GPU that's worth more than the whole system
HD4830, HD4770 (when it comes out), 9800GT, 9800GTX/GTS250. All normally <$200 and will be plenty for those games you run.
Old April 27, 2009, 05:29 PM
I would, if it is as the OP pointed out. A stop gap till he/she upgrades.
I agree with the rooster, If you can afford it and you have a PSU that's capable the HD 4890 is one sweet GPU.
Old April 27, 2009, 05:33 PM
3.0charlie's Avatar
What he said - even the venerable 8800GT would fit the bill quite nicely. And cheap.
Hydro-Quebec is salivating...
Old April 27, 2009, 05:53 PM
Yup, if cheap is what your after. Then I would buy the 8800 too. Then put a system together with a better card. It's hard to know what is going on in someone else's brain/wallet though.
Keep in mind he/she said "I would like to get a larger monitor in the future as I watch quite a bit of video on my computer".
[FS] lets Help put me through school thread! mattlef Buy/Sell & Trade 47 February 23, 2009 02:02 PM
Anyone want to school me on the 975 chipset? Nodscene CPU's and Motherboards 4 December 9, 2008 07:03 AM
Help with OC'ing old school style Tazer-[X] Overclocking, Tweaking and Benchmarking 19 August 17, 2008 10:24 PM
Laptop for School JD Mobile Computing 9 June 9, 2008 06:29 PM
Finding a laptop for school Amon Troubleshooting 11 August 23, 2007 09:34 AM
