Old April 21, 2009, 01:58 PM
martin_metal_88's Avatar
Question GPU bending in case
Many of you, probably about 90% or more have huge video card. Stock cooler are most of the time made for prevent the card to fold itself witch solid casing. But, when having a lighter cooler like Arctic cooling accelero twin turbo or Dark knight cooler from ASUS you can see the card fold by time.
Does any one here, know any way to prevent this or to make a folded card straight back?
Thx guys.
Martin_metal_88
Old April 21, 2009, 03:31 PM
Dr_BenD_over's Avatar
I actually wound up putting in supports when I had 6800GS's, but I haven't worried about it since that time.
If it's stupid and it works, it isn't stupid.
Old April 21, 2009, 04:41 PM
Pretty interesting. What are you using for doing this? Plastic glasses can do the job?
Thx
Martin_metal_88
Old April 21, 2009, 05:01 PM
MpG's Avatar
MpG MpG is offline
Unless it's really bending badly, I wouldn't worry too much. I've hung plenty of cards with full-cover copper waterblocks attached to them, and never had an issue. If you want to stop it anyway, you'll have to either run a piece of string from the roof of the case, or put a piece of something plastic/wood underneath the cards to prop them up. I wouldn't do the second if the case gets moved a lot though, since the prop might start rubbing against one of the circuit traces on the board.
Old April 21, 2009, 07:39 PM
Retro's Avatar
A quick solution for my card:
When I installed the HR-03 GTX and all of the various Enzotech sinks, and the dual Skythe 120mm fans, needless to say, there was some warping of the pcb.
I cut an old cathode ray tube (the blue tube under the far right side of the card in the photo) to size, and put some plastic washers on it for insulation and fine adjustments. Then I put a bolt with plastic washers on it through an open hole in the back front corner of the card, and rested it on the tube. The bottom of the tube is held to the base of the case with the velcro pad it came with.
This straightened the card nicely and adds enough support, but is still easily moved for card removal.
Latest build:
i5 750@3800MHz 20x190@1.38125v
Noctua NH-U12P/NF-P12
4G GSkill DDR3 2000 Ripjaws
Asus P7P55D-Pro
2x EVGA GTX275 in SLI
PC P&C 750 Silencer
Cuda 500
Antec 902
W7 64 RTM
Old April 22, 2009, 04:15 AM
Thx
Martin_metal_88
A bunch of these stacked on top of each other with one F/F at the bottom and an M3 screw at the top.
Old April 22, 2009, 06:20 AM
IRQ Conflict's Avatar
Water.
I want to die peacefully in my sleep, like my grandpa. Not like the passengers in his car, screaming and crying.
Everything but the GPU xile042 Video Cards 9 December 11, 2008 09:09 PM
New GPU-Z available Dwayne Video Cards 5 September 18, 2008 10:18 PM
Help, Need a new GPU!!!! bushwickbill Video Cards 14 April 14, 2008 07:22 AM
best way to test an OC'd gpu djnocide Video Cards 8 February 26, 2008 08:47 AM
A+ Case Black Pearl WCR Edition ATX Case Babrbarossa Reviews & Articles from the Web 0 June 19, 2007 09:28 AM
