Old April 10, 2009, 12:59 PM
clone63's Avatar
Default 9500gt sli
MY budget is low on getting a new PC so I inquired about this one for 300$
Ultra 600W Power Supply
AMD Athlon 64X2 2.4GHz CPU
ASUS A8N-SLI Deluxe Motherboard
Realtek ALC850, 8-channel CODEC
4GB DDR RAM
2 x EVGA GeForce 9500GT 1GB PCIE SLI Video Cards
3 x 80GB SATA Hard Drives RAID 0
The 9500gt is a budget card but I'm not really looking for miracles. If I can get a smooth fps on newer games at mid-low settings would be fine for me. For that deal, would it be worth it to sell them both and maybe just get a better card when I have a better mobo?
I should note the older motherboard is only PCIe 1.0, how would effect SLI? I've been running a single core, single GPU system for a few years so I am out of the loop.
Old April 10, 2009, 02:05 PM
jcmaz's Avatar
dude, just sell the 9500GT's and buy a 9600GT or something
also, it depends on ur power supply.
Check NCIX regularly for cheap video cards
Old April 10, 2009, 03:17 PM
IRQ Conflict's Avatar
Those drives wouldn't be Maxtors would they? I have an A8N-E that has serious issues with file corruption when the on board LAN is enabled.
I would try to go with a Intel or ATi chipset for the MB.
Old April 10, 2009, 05:14 PM
clone63's Avatar
The drive is unfortunately unidentified.
Old April 10, 2009, 06:18 PM
What is the warranty like? And is the store reputable?
Old April 10, 2009, 06:30 PM
SKYMTL's Avatar
HardwareCanuck Review Editor
Ditch the 9500GT. For $300 you can but a HD4870.
Old April 10, 2009, 07:18 PM
been seeing 512 4870s@ around 200-250 lately
maximus IV extreme @ 5.1 1.41v
evga e760 +920 4.8 water5.0+ on phase linx stable
gtx285 tri-sli
dfi ut-p35 lt
e8600@4.6 1.38v
too much ram
Old April 11, 2009, 09:24 PM
clone63's Avatar
The 300$ 4870 eats the majority of my budget
Old April 12, 2009, 07:47 AM
SKYMTL's Avatar
$164 for a HD 4850 512MB
Old April 12, 2009, 10:41 AM
somecanadianguy's Avatar
I just built an i7 system and got a 9500gt because I had to save some money. Actually, I tried to switch out for a Radeon 4670 at the last minute but got the 9500gt instead anyway. It's not a great card but it's really not that bad either. I can play Oblivion with most settings on max on at 1280x720, and even at my monitors max 1600x900 I only have to tweak a few settings to get it playable. I plan to upgrade the card soon... evga has a 90-day stepup program that I may try out... but for now I'm pretty happy with what I have.
9500gt DDR2 on i7 920 DDR3??? somecanadianguy Video Cards 11 April 12, 2009 08:54 PM
9500GT? HiTempguy Video Cards 37 April 6, 2009 05:46 PM
Help with Zotac 9500gt tcos Video Cards 20 February 13, 2009 06:24 PM
9500GT cooler Sniper Video Cards 5 November 10, 2008 06:52 AM
ASUS Launches Overclocked GeForce 9500GT MAC Press Releases & Tech News 0 July 29, 2008 09:45 PM
