Old April 9, 2009, 05:56 AM
SKYMTL's Avatar
HardwareCanuck Review Editor
I want to see a log of GPU load and clock speeds from this setup. With the 9.4 Beta, the HD 4890 stayed at stock speeds when at idle and then downclocked when it was under load. 9.4 WHQL might be different though.
Old April 9, 2009, 06:01 AM
If you point me in the right direction with software I can do so. Does speed fan do this? I can't remember. I remember it recording CPU load and speed, but not gpu.
Old April 9, 2009, 06:07 AM
SKYMTL's Avatar
GPU-Z will do it. There is a pull-down menu next to each section in the Sensors tab. Disable logging on all of the sensors except Core Clock.
Old April 9, 2009, 06:21 AM
I will does this later today when I do the vantage numbers for now I nap.
Old April 9, 2009, 07:00 AM
IRQ Conflict's Avatar
Originally Posted by sheepdogexpress View Post
Yes I am using 9.4. However, it looks like the drivers themselves are not futuremark approved, they are too new.
Heh, the last I checked neither were the 9.3's.
Thanks a bunch for your efforts!
I want to die peacefully in my sleep, like my grandpa. Not like the passengers in his car, screaming and crying.
Old April 10, 2009, 12:52 AM
Huh when I run the log, I got a gap exactly when I ran 3dmark VA.
Heres the gap.
2009-04-10 01:32:07 , 240.0 ,
2009-04-10 01:32:08 , 240.0 ,
2009-04-10 01:32:09 , 240.0 ,
2009-04-10 01:44:29 , 240.0 ,
2009-04-10 01:44:30 , 240.0 ,
2009-04-10 01:44:31 , 240.0 ,
Between that time 3dmark VA was running.
Also when I disabled everything except cpu clock I still logged a couple other and got a confusing file.
Sorry for the late update. But I was busy for the day. Benching time comes at night.
But there are results to show that they clock independently during a run.
Man those AMD runs like crap in Vantage.
Old April 10, 2009, 05:42 AM
Yeah sheepdog I have the same problem. GPUZ doesn't properly support the card yet I guess.
Old April 10, 2009, 05:53 AM
Its taking FM a while to approve 9.4. My results get taken down so quickly.
Are their any good free programs that allow for screen shots. Nevermind, I will just use PS again.
  #19 (permalink)
Old April 10, 2009, 06:47 AM
Try Infraview. It's a great little program.
  #20 (permalink)
Old April 10, 2009, 06:49 AM
Thanks I'll try it later. PS such a chore using because you have to do some much work to get a usable format and size.
Innovation Cooling 7 Carat Diamond TIM Test results thread *NOW ACCEPTING RESULTS!!* Nademon Overclocking, Tweaking and Benchmarking 254 December 14, 2011 08:18 PM
Some home-done 4890 results Oversized Rooster Video Cards 11 April 8, 2009 01:40 PM
Xfire a 1 GB 4870 with a 512 MB SneakySnake Video Cards 1 March 8, 2009 06:31 PM
Xfire cmac79 Off Topic 0 November 18, 2008 10:19 AM
4870X2 Sapphire xfire (crashing) cmak Video Cards 4 October 9, 2008 03:08 PM
