Old April 7, 2009, 05:41 PM
Default Bought a 4890 1GB - How will my system do?
Hey guys,
I am upgrading from a 8800GT 512MB to the recently-released 4890 1GB.
I have the following specs, exclusive of the video card:
  • Q6600 Core2Quad @ 3.2GHZ
  • 4GB RAM
  • P35-DS3L motherboard
  • Enermax EG495P-VE Noisetaker 485W Power Supply
  • 1 x 200GB IDE Drive
  • 1 x 300GB SATA drive
  • 1 x 1TB SATA drive
  • 1 x DVDRW Drive
  • 1 x DVD-ROM Drive
I guess I have two questions:
  1. What will be the bottleneck you forsee in this system CPU? Video card?
  2. Is my Power Supply going to do the trick? If not, I can disconnect the DVDROM and the IDE drive, if that helps?
Thanks!
Old April 7, 2009, 05:58 PM
gingerbee's Avatar
possible cpu
Old April 7, 2009, 06:00 PM
ImmaPC's Avatar
1. Since your Q6600 is Quad-Core and because it is overclockedo to 3.2ghz, it should not be a bottleneck at all for the 4890, and if so only an unnoticeable difference in FPS when gaming. If worse comes to worse see if you can squeeze another 1-400MHZ out of it, get a better HSF if you haven't already, etc.
2. Your PSU will positively, absolutely NOT do the trick. I would get a 550W bare minimum. If you unplug the IDE HDD and DVD-ROM drive it might do the trick, but then again chances of that are still small. If you want to have full-on functionality with everything you currently have running in your machine, a 600W would be ideal.
A10-5800K,
F2A85M-PRO
8GB DDR3-2133 CL9
2x XFX 7870
Adata SX900 256GB
Toshiba 1TB
Galaxy 1000W
Antec One
Old April 7, 2009, 06:09 PM
gingerbee's Avatar
wow i did not notice that psu i have never had good luck with enermax. immapc i am in total agreement
Old April 7, 2009, 06:24 PM
your psu will not cut it even if u unplug everything else
i'm usin a northQ 850 watt with my 4870 i think 650 will be better with a quad for U
maximus IV extreme @ 5.1 1.41v
evga e760 +920 4.8 water5.0+ on phase linx stable
gtx285 tri-sli
dfi ut-p35 lt
e8600@4.6 1.38v
too much ram
Old April 7, 2009, 06:27 PM
Oversized Rooster's Avatar
Like the other guys, I recommend that you upgrade your PSU to a far better one.
I am running a 4890 1GB together with a Q9450 @ 3.6GHz and 4 hard drives on a 750W PCP&C.
Machine: Intel 6800K | Asus X99-E | 32GB Corsair DDR4-2666 | 500GB Samsung 960 EVO NVMe | 6TB WD Black | 2 x 4TB Hitachi 7K4000 | Corsair 750D | Seasonic XP-860 Platinum | 4GB GTX 970 G1 Windforce | 2 x 27" Samsung S27D390HS PLS | Win10 Pro 64-bit
Old April 7, 2009, 07:53 PM
ImmaPC's Avatar
^^Ah, but your 750W might be a bit too much for your setup, Oversized Rooster. That PSU could easily handle a second 4890!
@Amorak: Definitely, Definitely, DEFINITELY get AT LEAST a 550W, even 550 is stretching it. Recommended would be 600-650W. HX620, Silencer 610, anyone?
A10-5800K,
F2A85M-PRO
8GB DDR3-2133 CL9
2x XFX 7870
Adata SX900 256GB
Toshiba 1TB
Galaxy 1000W
Antec One
Old April 7, 2009, 07:59 PM
Retro's Avatar
The PCP&C 750 is often on sale online for a very reasonable price. In these days of 1000 watt+ units, I don't think 750 is too much.
Dam good power supply.
Latest build:
i5 750@3800MHz 20x190@1.38125v
Noctua NH-U12P/NF-P12
4G GSkill DDR3 2000 Ripjaws
Asus P7P55D-Pro
2x EVGA GTX275 in SLI
PC P&C 750 Silencer
Cuda 500
Antec 902
W7 64 RTM
Old April 7, 2009, 08:39 PM
geokilla's Avatar
Get a better PSU, such as the Corsair HX620. It definitely won't provide enough juice for a 4890. Even if it does, I'd worry bout it.
What resolution are you gaming at? The resolution could also determine whether your CPU is a bottleneck or not.
Old April 7, 2009, 10:20 PM
Anyone got some deals on a good PSU?
Tags
4890 , power supply
ATi 4890 unveiled! Silvgearx Press Releases & Tech News 8 April 1, 2009 04:37 PM
4890 Spotted snoosebum Video Cards 7 March 29, 2009 06:40 PM
First Pics of the Ati 4890 Jonwall Rumor Mill 7 March 18, 2009 04:09 PM
[WTT] My EVGA 9800GX2 for your XFX 4870 XXX 1GB/512 (1GB Preferably) Apollo4g Buy/Sell & Trade 7 January 23, 2009 12:43 PM
