Old April 7, 2009, 10:38 PM
rjbarker's Avatar
Corsair TX650W 650W Atx 12V 52A 24PIN Atx Power Supply Active Pfc 120MM Fan - DirectCanada
PC Power & Cooling Silencer 750 Quad 750W ATX V2.2 EPS12V 24PIN SLI Active PFC Power Supply Black - DirectCanada
Firestrike Extreme: 21.452
MARK 11: 32.530
Old April 8, 2009, 09:23 AM
Canada Computers - : PC Power & Cooling (PPCS750QBL) Silencer 750 Quad 750W ATX V2.2 EPS12V 24PIN SLI Active PFC Power Supply Blue.=
This 750w pc power n cooling has a $25 mir. Gets it down to $112 but then there's tax and shipping.
DC has Corsair TX750W 750W ATX 12V 60A 24PIN ATX Power Supply Active PFC 140MM Fan - DirectCanada
Gaming FX 8350 4.4GHZ / Tuniq Tower 120/ MSI GTX 1070 Armor / G Skill 32GB / S12D 850w/ GA 990FXA-UD3 /SSD 240GB , WD1TB FALS, 3TB Toshiba / Dell IPS 1920x1080/ Win 10 64
Daily Use x4 965BE 3.4GHZ/GA 970 Gaming/ Rx 580 8GB /EA750w/4x4GB ram/Win 10 64 and 24TB of hdds
Old April 8, 2009, 10:10 AM
Realityshift's Avatar
Id go with a 650 if your not planning on crossfire later on, even a VX550 would do for that build I would think but if it where me id go with the 650w =)
The Builders Hammer
Old April 8, 2009, 11:00 AM
Are you guys SURE he needs at least 650W?
[H] Enthusiast - ASUS EAH4890 Video Card Evaluation
Full system load power draw at the wall: 363W
AnandTech: ATI Radeon HD 4890 vs. NVIDIA GeForce GTX 275
Full system load (not sure whether it's at the wall or not): 287W
Sapphire Radeon HD 4890 1GB Review
Full system load: 319W
Looks like a good 500-550W would be just fine for a single 4890 (HX520, VX550 or similar)
Do note that the test system used in the HardOCP review were with a QX9770, a Core i7 920 was used in the HWC review, and i7 965 was used in the AnandTech review.
Old April 8, 2009, 11:14 AM
according to the specs, this cards needs 500w psu with two pci-e connectors
Old April 8, 2009, 12:52 PM
Thanks, I appreciate the objective, fact-laden post. I remember when I got the 8800GT people were telling me 485W PSU would be cutting it - But I had no problems.
So my plan is to give the 4890 a shot with my 485w, and if it works, great, if its unstable, then I'll sell it and upgrade.
Thanks to everyone for the replies!
Old April 8, 2009, 02:58 PM
mchutch's Avatar
Unfortunately cheap power supplies may risk your entire system. Being in Calgary I'd go with this...
BFG GS-550 550W Power Supply ATX V2.2 EPS12V Active PFC 20/24PIN 6PIN & 8PIN PCI-E 140MM Fan - DirectCanada
If you can spare more cake...
I don't think your CPU will be a bottleneck, but without a PSU upgrade your 4890 probly will not have enough power and it may perform like a 4650...lol.
As for other system possibilities, what speed is your RAM?
Old April 8, 2009, 03:06 PM
IRQ Conflict's Avatar
I'm running a 4890 with a Q6600@3.2Ghz. Nary a problem. Running Crysis @ 1920x1200 4xaa. 20-40fps feels like 120 though. UT3, eats it alive! Enemy Territory, not a problem. Though some graphical anomalies which I chalk up to driver support or rather the lack thereof.
Had similar but worse problems when I ran two X1950 Pro's in CF.
  #19 (permalink)
Old April 8, 2009, 07:16 PM
People tend to overrrate how much power is needed to power systems. Though if you do find you're having performance issues, computer tends to lock up more and problems such as those you should proabably invest in a new PSU.
  #20 (permalink)
Old April 8, 2009, 07:36 PM
Killswitch's Avatar
This will give you a rough idea of what you should have for a PSU according to what else is in your system. It doesn't have the 4890 to choose from yet in the video card drop down menu, but I think a 4870 is pretty close in terms of power consumption.
eXtreme Power Supply Calculator Lite v2.5
Tags
4890 , power supply
ATi 4890 unveiled! Silvgearx Press Releases & Tech News 8 April 1, 2009 04:37 PM
4890 Spotted snoosebum Video Cards 7 March 29, 2009 06:40 PM
First Pics of the Ati 4890 Jonwall Rumor Mill 7 March 18, 2009 04:09 PM
[WTT] My EVGA 9800GX2 for your XFX 4870 XXX 1GB/512 (1GB Preferably) Apollo4g Buy/Sell & Trade 7 January 23, 2009 12:43 PM
