Old April 7, 2009, 12:22 PM
mattydies's Avatar
Default New Card - 9800gtx+ - I have a couple Q's
I just bought a used EVGA 9800gtx+ from a friend this weekend. Popped it in the computer, installed the cd, runs great.
I have a couple questions.
1) Should I update the driver/forceware? I am not sure where to find which version it is, but the "driver date" is Dec 26, 2008. Where can I find which version I am using?
2) I want to overclock the card. I figure I may as well use the EVGA software that came with it. What is the order of overclocking? I assume do the GPU first, then what is the next step - shader or memory? Am I right in about the process or????
Any other thoughts?
Old April 7, 2009, 12:30 PM
Jake_HT's Avatar
Yes you should definitely update the drivers. Uninstall the video drivers first and delete the files from the NVIDIA folder in C drive. Some recommend using a driver cleaner.. however you can be fine without it.
You can find the drivers for your system here:
Drivers - Download NVIDIA Drivers
I haven't used the EVGA overclocking tool, but RivaTuner works very well and is used by many.
http://jakeht.deviantart.com/
Old April 7, 2009, 12:47 PM
JD JD is offline
Which is all EVGA's software is, just has an easier to use GUI.
Old April 7, 2009, 07:19 PM
rjbarker's Avatar
Congrats on your new 9800 GTX+, the same card I threw in my 2nd Rig...greaqt Card for the $$$...I was totally impressed playing titles such as Crysis Warhead, FC2 etc...
Precision is a great OC'ing tool and a whole lot easier and less confusing the Riva (same developer)..many questions you;'ll have can be found here, including OC'ing anbd those Cards OC like the banshee, I know I had my Core running at 810 Mhz..can't remember what I had shaders and Memory at..also quite cool compared to my 280's..Max Temps under load 68c Fan speed at 60%...enjoy!
EVGA GeForce 9 Series
Classified Ultra SLi "Procyon"
http://i30.photobucket.com/albums/c3...2/DSC02888.jpg
http://i30.photobucket.com/albums/c3...2/DSC02889.jpg
Evga 4.2 Ghz Club....
[WTT] WTT: 9800gtx for better video card Table21 Buy/Sell & Trade 1 July 25, 2009 09:59 PM
SLI 9800GTX/9800GTX+ Problem Realityshift Video Cards 5 March 12, 2009 10:56 AM
[WTB] Desperate plea for 9 Vid card spring screws for 9800GTX+ Sniper Buy/Sell & Trade 7 February 14, 2009 11:27 AM
A couple of questions about Vid card differences Shadowmeph Video Cards 4 December 2, 2008 12:11 PM
