Old April 6, 2009, 01:19 PM
Default BottleNecking?
How do i know if my CPU is bottlenecking my XFX285 BE
CPU is OC to 4.125ghz.
3dmark06 score
19289.
Old April 6, 2009, 01:24 PM
only in benches, not in real-world apps.
Old April 6, 2009, 01:35 PM
geokilla's Avatar
What CPU do you have? What resolution are you gaming at? What's your rig detail? Try to provide these kind of information.
Old April 6, 2009, 01:59 PM
rjbarker's Avatar
When running a Benchmark such as 3D MK - if your score continuosly gets better n better as you increase CPU speed, yuo know that your CPU is "holding back" the data from being processed by your GPU.....on the other hand, if increasing CPU speed results in very little increase in performance, you know your GPU is holding back the Data being processed by your CPU......
Be aware that Programs such as 3DMK06 and Vantage are optimized for either CPU or GPU and this is most defintiely factored in....
Firestrike Extreme: 23.772K
https://www.3dmark.com/fs/17562471
Timespy: 18.613K
MARK 11: 40.185K
https://www.3dmark.com/3dm11/13079691
Old April 6, 2009, 02:57 PM
I can get anymore outa this CPU... At least i dont think i can...
Wish thier was a easyer way to check
Old April 6, 2009, 03:18 PM
SugarJ's Avatar
Back off your OC instead of bumping it up. That will tell you the same thing. If your framerate is affected, it's your CPU limiting your FPS in that game.
This changes from game to game.
Old April 6, 2009, 05:23 PM
MpG's Avatar
MpG MpG is offline
Yes and no. Certain benches within those programs are CPU-only, so even if you somehow had your processor at 10Ghz, you'd still see more performance from getting it to 10.1GHz. So make sure you only look at that 3D portions of the score breakdown.
At a guess, I'd venture that the only game you could possibly be seeing CPU bottlenecking would be something like large-scale SupCom.
Old April 6, 2009, 05:25 PM
3dm06 is more cpu than gpu.
Hence why upgrading a cpu or overclocking it can make a huge increase in score.
Old April 6, 2009, 05:26 PM
SupCom, FarCry2(only affects minimums though), and GTA4(gains for cores, not so much frequency after 3.6ghz)
keep in mind that programmers are going for worst-case scenarios(minimum requirements), so rarely is cpu overclocks going to affect performanec, especially in newer titles.
Old April 6, 2009, 05:28 PM
Dual core processors stop showing any real significance in frames at about 4ghz. Anything beyond that really makes no difference.
What do you suppose is bottlenecking this PC? LookAQuesadilla Troubleshooting 14 April 30, 2007 09:16 AM
