Hi everybody,
So I've got a few questions and I was hoping to get some of your input :)
I'm currently running on a q6600 at 3ghz with 4gb of ram (vista64), and an old 8800gts 640mb 112stream processors. For those who are unfamiliar with this gpu, it's pretty much on par with the 8800gt 512. I have a 24" monitor, so I play at 1920x1200 when I can
Now, my videocard is starting to show its age. I've had to downclock it to reference speeds (from evga's ssc clocks) as well as crank the fan to max everytime I play a game.
I've been thinking about getting an upgrade, and I'm not sure which path to take...
One option for me is to utilize my 680i (asus p5n32-e sli) board and run a pair of nvidia cards. The 260 216(65nm) runs for about $200 after MIR on ncix when you can catch it on sale.
I was thinking about getting one now and throwing a second card into my rig later this year... Perhaps when sc2 comes out?
From what I've seen, the price:performance of the 260 is pretty fantastic at $200.
My other option is to get a 4890 and overclock it as much as possible. To me, the 275 isn't quite worth it, as the cost is (slightly) higher than the 4890, but the performance is less when overclocking is taken into consideration.
There are several things for me to consider:
1) How does the price:performance of sli 260's compare to an overclocked 4890?
-A single 260 is about a 50% performance increase over my current gpu.
-An oc'ed 4890 is roughly a 30% increase over the 260, but 50% increase on the price
-Does the price:perfomance ratio between the 260 and 4890 change when you take sli scaling into consideration?
2) Can my psu even support sli 260's?
I'm running off:
-q6600 g0 stepping, oc'ed to 3.0. I can run at about 3.3, and can probably push it to 3.4 if I optimize everything.
-2x 2gb dimms of ddr2, patriot memory. It's overclocked a bit as well, but I can't remember the voltage
-A bundle of 120mm fans at different speeds. Maybe, 7/8 all together?
-1 dvd burner
-A cheapo soundcard that came with my mobo (it doesn't have onboard sound)
-A primary sata2 hard drive at 7,200rpm, and two older ide drives at the same speed.
-The older two drives I can cut from my rig if need be.
I have a corsair hx620 power supply and I'm not sure if it's enough to run a pair of 260's.
Now I suspect that the sli 260's yield a better price:performance than the 4890. Even if they don't, a pair of 260's should perform better than the 4890. (And closer to the fps that I'm looking for in crysis
However, if an upgrade to a new psu was necessary, it would pretty much throw off that price:performance ratio right off.
I'm sure either of these cards will handle starcraft 2 on max easily. Left 4 Dead and UT3 aren't an issue either.
It's crysis that I'm somewhat fixated upon. I
would like to play crysis at 1900x1200 on tweaked high settings with an average fps of about 40.
Also, I'm looking forward to the crytek3 engine
What do you guys think?
Any sort of input is greatly appreciated!
Thanks in advance
-JD
ps. Silly question. Is it possible to run an nvidia, secondary gpu for dedicated physx when your primary is an ATI card? Probably not, but I thought I'd ask.
