Old April 3, 2009, 08:20 AM
Varroa's Avatar
Default PhysX card question
Hi Guys, got a quick question. I have a ATI 4870 card which does all my graphics and I have an empty PCI-e x16 slot (x4 electrical, 1.0 slot) and a 8800GT doing nothing. Can I add the 8800GT card to the slot and use it for PhysX stuff or would there be a conflict?
GAMER: Win10 Pro x64, I7 8086K (corsair H110i), Asrock Z370 Taichi, EVGA GTX 1080 FTW, Gskill 4 x 8 GB DDR4 3200Mhz, Samsung 970 EVO 500GB M.2. NVME SSD, Western Digital Blue 1 TB M..2. SSD. Crucial M4 256GB, Mushkin 480 GB ECO SSD, HX750W, Sound blaster Z, & Phanteks Enthoo Pro M
Lenovo Ideapad Y510p: i7-4700MQ 2.4GHz (undervolted by 80mV), 16GB DDR3L-1866MHz, Intel GMA 4600HD / SLI'ed Nvidia Geforce GT 755M 2GB GDDR5, 240 GB Crucial SSD, 128GB M.2 SSD, 15.6" HD+ Glossy LED
Old April 3, 2009, 05:46 PM
mchutch's Avatar
I/m not sure but since your using Win XP I think you can run PhysX on the 8800GT. With Vista this is not possible but I believe in XP you can install both Catalyst and Forceware drivers. Then in the Nvidia control panel choose GPU for PhysX.
I am just stating what I read about...I'm sure some here have tried this an can tell you by experience.
Old April 3, 2009, 06:07 PM
Chilly's Avatar
Its not possible in Vista, but will be(and is in the beta) possible in Windows 7, I don't know about XP.
Old April 3, 2009, 06:11 PM
Neither XP or Vista like to play nicely with different brands.
They say Win7 will fix this.. but time will tell.
Old April 4, 2009, 12:22 AM
Here read this thread
and it does work in XP
http://www.hardwarecanucks.com/forum...850-physx.html
Old April 4, 2009, 11:06 AM
Varroa's Avatar
Sweet, I may give this a try. I am also using Windows 7 so when that finalizes I will give it a try. Thanks again!
Tags
ati , physx
Of 4850 and PhysX ImmaPC Video Cards 14 March 5, 2009 11:39 PM
video card size question esanity Cases 3 February 17, 2009 12:06 AM
New PhysX driver burebista Video Cards 19 August 12, 2008 06:23 AM
Internal Card Reader Question.. Kayen Storage 9 July 25, 2008 05:38 AM
Ageia PhysX Prof. Dr. Silver Video Cards 5 November 29, 2007 02:13 AM
