-   -   Can I run my G31 integrated graphics with my 4870? (http://www.hardwarecanucks.com/forum/video-cards/16104-can-i-run-my-g31-integrated-graphics-my-4870-a.html)
superj March 23, 2009 05:47 PM
I'm trying to figure out if I can boot up from integrated x3100 graphics so I can flash my 4870 firmware. If I enable the internal graphics in BIOS the 4870 does not seem to be active in any configuration. Do PCI-E lanes get reallocated to the x16 slot when I stick an external card in?
Silvgearx March 23, 2009 06:28 PM
http://www.hardwarecanucks.com/forum...83664486f6.jpg
Your talking about your ASUS p5kPM-CM motherboard right?
If so, i think you can run the pc without an GPU when you set the initiate graphic adapter to [IGD]
Not 100% sure tho. :doh:
superj March 23, 2009 07:05 PM
Yes, it's my ASUS p5kPM-CM. I made sure that the internal graphics were enabled along with the PEG. I'll try a few more combination of bios options tomorrow.
Does that force x1 PCI/E option do anything that is worth playing with?
Thanks for the reply.
