Old March 23, 2009, 03:05 PM
Question Sapphire Radeon HD4850 with water cooling system from coolermaster?
Hey guys I need your help.
I have a Sapphire Radeon HD4850 1Gb with fansink and the Coolermaster Aquagate Viva duo.
I've tried the stock video card and it runs perfectly fine but when I install the watercooling system it crashes on boot and a red LED turns on in the video card.
Is not the power since I have a coolermaster extreme 550Watts, and its not the watercooling systems since I have it running anyway to cool an AMD Phenom X4
Any ideas on how to solve this problem???.
Carlos
AMD Phenom X4 2.2 Ghz
6 Gb DDR2 800Mhz RAM
Sapphire ATI Radeon HD4850 1Gb
Windows XP 32bits SP3
CoolerMaster CM690 w/ Aquagate viva duo
Old March 23, 2009, 03:23 PM
plug the stock fan in.
Old March 23, 2009, 06:15 PM
JD JD is offline
Well that really isn't a good power supply but whatever, it's not the problem at this point in time.
That watercooling system is garbage though and I highly doubt it can cool a HD4850 properly, especially if you have your CPU running on it. A dual 80mm radiator of unknown quality + some random low-flow pump is just asking for trouble. I kind of doubt it's even doing any good for your CPU. Probably be better off with a decent heatsink.
Old March 24, 2009, 08:59 AM
Smile
I plugged the fan :)
And I thank you for the advice about the cooling system...
Which would you recomend??
Thank you both for the advice
Carlos
Old March 24, 2009, 09:01 AM
JD JD is offline
If you're serious about water cooling, head over to the Water Cooling section and make a post there. Best to build a custom setup seeing as you want to cool your Phenom X4 and a HD4850. No pre-built kit is going to be able to handle that heat load IMO.
Old March 24, 2009, 09:24 AM
Did it work with watercooling, but the stock fan plugged in? and it doesn't work without the fan plugged in?
Old March 27, 2009, 11:46 AM
Thank you jdrom17, I'll check that out...
It didn't work with the fan plugged in nor without it. And the card by itself won't work without the fan plugged in, I assume due to a heat protection system.
Carlos
Tags
video card , water cooling
Sapphire Radeon HD4850 dual-slot fansink Mr. Gruntsworthy Video Cards 2 October 13, 2008 07:11 AM
LF High End Water Cooling System renoracer Buy/Sell & Trade 0 September 10, 2008 09:24 PM
FS: Complete AMD System cheap 7600gs 512mb agp 6600gt agp Water cooling kits MarcusFoX Buy/Sell & Trade 7 May 17, 2008 12:19 PM
WTB: Decent Water Cooling System For My Q6600 saihossoku Buy/Sell & Trade 26 March 10, 2008 06:15 PM
