Old March 14, 2009, 02:27 PM
Default Help! Card Not working fully?
I JUST bought a BFG GTX 295, the whole 2 GPU in one.
I have a P5K deluxe mobo and I'm running 4gigs of ram and an e8400 proc. OCed at about 4ghz.
I also have a 750watt sli/crossfire enhanced PSU.
My issue at hand is the fact that my framerates are even lower than if I was using my old 260 GTX. Or even my 9800 GTX.
What's going on? I checked GPU-Z and the specs are even lower, It says SLI is working, but the spec's are lower than the listed specifications on the box ect.
I have the latest 180.2 drivers for my 64-bit vista from nvidia.
Another thing I noticed is that the second core doesn't get near as hot as the first. I'll be peaking 60 and the second will sit almost idle at 50 or 53.
I've used some tests to determine what my FPS is in relation to other cards and a benchmarking tool.
I'm rated lower than a 260 OCX.
Help. I'd love to use this graphics card to its fullest potential.
Old March 14, 2009, 02:53 PM
182.xx drivers**
Old March 14, 2009, 02:56 PM
3.0charlie's Avatar
1. Did you fully un-install the drivers when swapped cards.
2. If you look at Device Manager, are 2 cards shown.
Hydro-Quebec is salivating...
Old March 14, 2009, 03:02 PM
Didn`t do 1. Just did it now.
And two. Yes two are shown. But I`m getting such bad FPS. I`ll repost after I reboot.
Old March 14, 2009, 03:08 PM
Nothing. It's still not working 100%.
Old March 14, 2009, 03:38 PM
rjbarker's Avatar
Sorry about your whoas .....exactly the reason why I have never bought into nVidias "Dual PCB Boards"....seems as tough they have traditionally been problematic.
Firestrike Extreme: 21.452
MARK 11: 32.530
Old March 14, 2009, 04:27 PM
KaptCrunch's Avatar
welcome to the world of hype
its all marketing for tri-sli
find me a game that uses all its power today?
gpu-z tells the whole story here
this why i'm keeping my 9800gtx
bigger clocks over the 200 series
Old March 14, 2009, 04:31 PM
Dwayne's Avatar
What are you benchmarking? I have a BFG 295 and I have had no problems that I can tell. You need to check the NVidia Control Panel and make sure Multi-GPU is enabled? Also use the Manage 3D settings for games and check the recommended setting for SLI as some applications run best forced to single GPU operations.
Perhaps you have a dud? Get RivaTuner and monitor the speeds, or use another program like GPUZ to see that the GPU does ramp up in speed on both the GPU and the RAM too.
Another program that can help is nHancer, though you need a small file that is on the forums, to force the machine to SLI mode... but the NVidia control panel should help.
Dwayne's Rig - Asus Prime Z370-A : i7 8700k : Corsair Vengeance 32 GB DDR4-3000 : Corsair RM650x PSU : Corsair H100i V2: Fractal Design Meshify C : EVGA GTX 1080 :
HTPC - GigaByte H67MA-UD2H : i3 2100 : 8 GB Mushkin Silverline Stiletto : Antec TruPower 550W : : Corsair H100 : Sapphire HD 6670 : Corsair 650D: Kingston 60 GB SSD Boot
Tablet - Samsung Tab A 10.1"
Wife's Rig - MSI GL72M 7RDX
Old March 14, 2009, 04:47 PM
hmmmmm..... this sounds like my problem.
My Rig
Intel i7 940
Rampage II Extreme MB
Corsair 6GB memory
Seagate 1.5TB HDD, Seagate 500GB HDD
BFG (Geforce GTX 295)
LG Blue Ray + HD Combo Optical Drive
Cooler Master HAF 932 case
Corsair HX1000 power supply
Samsung T260HD 25.5" LCD Monitor, NEC 1860NX 18" LCD Monitors
Cambridge Soundworks 2.1 Speakers
Logitech keyboard and mouse
MS Vista Ultimate 64bit.
Old March 15, 2009, 01:17 PM
It appears to be running better, I did a fresh install of vista because I had tons of overlapped drivers I never uninstalled.
Note to self: Uninstalling drivers is good for the long run.
DDCPX-pro, rpm not working? donimo Water Cooling 10 March 5, 2009 09:09 PM
new build not working satan_2.7 Troubleshooting 2 August 17, 2008 09:26 PM
FS: Ispiron 1501 fully loaded kcksteve Buy/Sell & Trade 0 April 29, 2008 05:57 PM
Pirates release fully cracked Vista install Babrbarossa O/S's, Drivers & General Software 9 June 29, 2007 02:48 PM
