Old March 5, 2009, 09:45 AM
Default Do I have enough juuuuice?
Hey all, just a quick question I was hoping someone could help me with. I recently ordered a sapphire HD 4830 video card and didn't realize until after that it has a PSU req, yeah I know, dumb... Apparently this video card requires 450W but my PSU is only 430W. I am hoping this 20W won't make a difference, but I've heard that as much as 550W is recommended. Will my 430W pull through for me?
Here is a link to the power supply I have. It's not a cheapy, but at the same time it's not top of the line.
tr2tt.com/products/psu/w006970/w006970.htm (sorry, can't post actual links yet, too n00b!)
The rest of my hardware is pretty modest with this video card probably being the best thing in my build. I have an Athlon 64 x2 3800 for a processor, MSI K9N Deluxe mobo, Seagate barracude 7200 (320gb) HDD, and a LG DVD-RW. So I wouldn't imagine all that is a big drain on the PSU, leaving ample power for my video card, or at least so I hope. If anyone could shed some insight to ease my worries while I wait it would be greatly appreciated!
Old March 5, 2009, 09:46 AM
Alright, past that 0 post silliness, here's an actual link.
Power Supply Unit Series- TR2 430W Power Supply
Old March 5, 2009, 10:09 AM
Soultribunal's Avatar
I personally wouldn't do it on that PSU.
Its got a paltry 18A on the 12V rail....
For Comparison, a Corsair 400w has 30A , and my Ultra LSP450 has 26A.
That might be too much stress for that particular unit.
So, I would either get a Better One around the Same wattage, or, go a bit higher into the 550 range.
My thoughts at least.
ST
www.realhardwarereviews.com
Old March 5, 2009, 10:14 AM
I'm going to agree. the amperage is too low on that 12v rail. I'd consider the Corsair 400 watt or another higher unit with a high 25+ amps on the 12v rail.
Old March 5, 2009, 11:22 AM
Thanks for the replies. I have another question quick question. What happens if I try it anyway? Do I just risk frying the PSU, the video card, or both?
Old March 5, 2009, 11:36 AM
Really Depends on a lot of factors.
If it is just too much for the PSU, you probably won't even get it to boot up.
If its borderline, it could powerup, but the second the Video Card starts taking more power while its working, it could give you random shutdowns etc etc..
Now, that being said, I don't know what the Over Current Protection is like on that particular unit is like.
I got away lucky when I fried my Power Up! 450W on the Test rig in my sig.
It was just the PSU that got cooked.
When a PSU Goes, it has the potential to destroy a lot around it. Which is why you will always see people going for more than their system needs to give a good buffer zone.
And, when a PSU Is running at full load it tends to Generate a ton of heat.
So ensuring it gets lots of air is a must as well if you are going to run in borderline.
Something to think about at least,
I've always gone for good Quality PSU's with more than I ever need to make sure I have the best chances of not nuking my computer.
Good Luck,
ST
Old March 6, 2009, 08:31 PM
aviduser's Avatar
Like everyone else has said, its better to go with something you can run safely. I recommend getting a psu that is around 750w, that way you can carry it over to the next rig. Plus you'd have the option of running two cards in the future.
But thats just my opinion, I bought a beefy power supply to handle upgrades and so far am glad.
I5 4670K 4.4ghz - Gtx 780 Amp - 2x4 Corsair Vengeance - MSI z87-g43 - Tx 850w - Asus pbq278q
Old March 6, 2009, 08:48 PM
kirk_d's Avatar
18A is the 90's!
Opty 170(naked) @2600 | Abit AT8 32x | EVGA Vanilla 8800gt 650/1625/950 | 2gb Ocz Pc4000Eb@260 | Audigy Gamer | Tx650 | Cm690 |
WC Loop: DD Cpx-Pro | HWL 240 Xtreme | D-Tek V2
Old March 7, 2009, 12:25 AM
MpG's Avatar
MpG MpG is offline
Yeah, so is 65% efficiency, and dual-80mm cooling fans. Not to belabor the point, but you're a prime candidate for a new power supply. Is doesn't need to be big - even a good 400W would be fine - but there is far better available these days, and just the improvements in electrical efficiency would likely offset much of the costs.
When SKYMTL tested out the HD4850 with a overclocked Quad-core rig, he found it pulling around 250W from the wall, and both your processor and video card should be equal to or less than those. So there should be some safety margin, even with the age of the PSU, and if you absolutely wanted to plug it in and run the rig, it would probably do it, unless the manufacturer overstated the ratings (not uncommon), but under no circumstances would I do anything remotely resembling overclocking with it.
Old March 7, 2009, 02:05 AM
Hey Flood,
I think you should be fine, I personally have experience with a 4850 running on a 350 watt with a 15 amp power supply for almost a year. No stability problems whatsoever. i would say to give it a try
Regards,
- Jesse
PC: Athlon X2 5000 BE@ 3.2 GHZ, 2GB DDRII 1066MHZ Buffalo Firestix ram, Gigabyte GA-MA78GM-S2H motherboard, Corsair HX650 watt power supply, Radeon 4850 videocard, Antec P180 case, two Seagate 320GB HD, Samsung Syncmaster 2443 24" monitor, JBL Platinum Series speakers.
