Old February 28, 2009, 09:50 AM
mailaw's Avatar
Default EVGA 260 or EVGA 260 216
Wich one do i get the base EVGA 260 or the one with 216 processing cores.
The lower one is more in my price range
NCIX.com - Buy EVGA E-GEFORCE GTX 260 576MHZ 896MB 2GHZ GDDR3 PCI-E Dual DVI-I HDCP HDTV Out Video Card - 896-P3-1260-TR In Canada.
But is the $80 worth it.
NCIX.com - Buy EVGA E-GEFORCE GTX 260 Core 216 55NM Mirror 576MHZ 896MB 1.998GHZ GDDR3 PCI-E Dual DVI-I Video Card - 896-P3-1255-A1 In Canada.
Resolutions are 1680 by 1050 - just wondering after looking at the benchmarks it doesn't look like $80 of performance for the higher model.
Maybe a 4870 512mb but I like Nvidia drivers, step up program and performance is slightly better for games and programs I'll use.
Need to know soon!
Old February 28, 2009, 10:25 AM
Eagle Eye's Avatar
It would be hard pressed to say you'd really notice the difference between the 2 while gaming, furthermore if the 1st one is within your budget that would be the one I would get. Assuming that your current card is far less powerful you won't be disappointed at all with either one you choose.
Regards,
EE
Old February 28, 2009, 10:54 AM
If you plan on folding or heavy gaming the 216 core runs much cooler and draws less power.
Just a thought. There is more than performance. The power savings alone over the life of the card will pay the difference.
RIG #1 - Intel E8400 // TRU-X 120 w noctua NF-P12 // GA-X38-DQ6 // GTX285 OC // 8g Ram OCZ Fatal1ty PC8500 // X-Fi Elite Pro sound // z-5500 speakers // OCZ 850w Gamer XTream PSU // WD Raptor 150g // Seagate 1Tb // 2xSeagate 500g ex// Logitec G-15 keyboard // Vista Ultimate 64bit
RIG #2 - AMD64 3500+ // Asus A8N-E // 8800GTS 512 OC // Enermax Liberty SLI 500W Modular PSU // WD Caviar 250g
Old February 28, 2009, 10:55 AM
CTA's Avatar
CTA CTA is offline
if you were me then i would pick gtx 260 core 216 or wait more...
honestly if you choose gtx 260 (core 192) then i recommend hd4870 since they are almost same in every games... gtx 260 core 216 is not...
Old February 28, 2009, 10:56 AM
Thund3rball's Avatar
At 1680x1050 you can max any game out with the 192 Core (lower one). And not that I have done a ton of research on this but the difference in performance I have seen is pretty small, even ay high resolutions.
"this is not troll. this is real deal!" - hohohee
Desktop:
See the drop down!
Laptop: Dell XPS M1530 \\ T7500 2.2GHz \\ 3GB 667 \\ 6 Cell \\ 8600M GT \\ 200GB 7.2K \\ WSXGA+ \\ Bluetooth/Wireless \\ MS Blue Track Mini \\ Vista Ult. (RED)
HEATWARE
Old February 28, 2009, 11:12 AM
"Quote This..."
For $80 and on a tight budget I'd get the 192 shader version. I have the 192 version and I do not want to upgrade as I got an absolute cherry card that is stable all day long at 837mhz core 1640mhz shader and 1215mhz memory. I am currently the #3 on 3dmark06 of all gtx 260's (23900)
Old February 28, 2009, 11:57 AM
CTA's Avatar
CTA CTA is offline
thats impressive... do you use water block on your video card?
Old February 28, 2009, 12:10 PM
The First Review of 55nm GeForce GTX260 - Expreview.com
and
Old February 28, 2009, 12:44 PM
arekieh's Avatar
if the 196 260 is in ur price range, the 4870 has equal performance for less $$,
It should be between the core 216, and the 4870 512mb imo.
Old February 28, 2009, 02:39 PM
mailaw's Avatar
If someone can find a cheaper 4870 other than the HIS at $206 from Newegg, please do.
The rebate on that card expires today and I don't want to have to get my rebate from them cause they seem iffy.
Not the HIS - no thank you - the evga is $220 with a $20MIR!
I'm ordering today within the hour.
Evga 8800 gt: Nvidia VS Evga drivers TwystedMonkey Video Cards 4 September 1, 2009 01:57 PM
VR-Zone & EVGA Forums - EVGA X58 SLI Classified - NF200 Monster! zlojack Press Releases & Tech News 26 March 19, 2009 06:05 PM
BFG vs eVGA chouchou Video Cards 37 November 19, 2008 05:47 PM
Fs: Evga 9800gx2, Evga 8800gts (512) Evilyeti Buy/Sell & Trade 15 October 27, 2008 02:05 PM
FS: EVGA GTX260 - EVGA 750i FTW kenken3686 Buy/Sell & Trade 2 October 2, 2008 07:28 PM
