Originally Posted by SKYMTL I tried a bit of overclocking last night and it was like bashing my head against a wall. The core got to something like 8Mhz above stock and I didn't get to the memory.
If I had to guess, the reason why the memory is at this speed is because they limited voltage to it in order to keep heat to a minimum. |
Most likely. Those chips aren't covered and probably don't dissipate heat all that well. Restricting voltage is definitely a compromise that had to decide upon, but for good reason. I don't think many people would want to overclock for a silent setup, alone most people that want an HTPC probably don't know how to overclock. Because the chips are quite large, they probably transmit heat throughout the entire PCB. Again, you probably won't see much of a performance increase at higher RAM speeds.
