Old February 26, 2009, 09:27 AM
Default Dual GTX285 SLI
I've only had this setup up and running for ~ 4 hours now but here are my first runs:
3DMark Vantage - 23748
ORB - Compare
3DMark06 - 23218
ORB - Compare
Not to bad for air.
Old February 26, 2009, 09:47 AM
SKYMTL's Avatar
HardwareCanuck Review Editor
Intersting, on my 3.8Ghz system and a single overclocked GTX 285 I hit close to 20,100. Is your i7 overclocked?
Old February 26, 2009, 09:49 AM
Same as yours, which you can see on the links.
Old February 26, 2009, 10:16 AM
Jake_HT's Avatar
Something ain't right about your 06 score... are you running the default test? I get 22978 and I have 9800GTX which are not quite near as fast as the 285's... for a difference of only 300ish points, yours should be much higher
http://jakeht.deviantart.com/
Old February 26, 2009, 10:32 AM
The MAX's Avatar
who has the physx enabled and who doesn't?
For a TRUE score you should disable physx.
- Antec 900 (modded) - Asus P5Q-Pro - 4GB Corsair Dominator DDR2-1066 -
- Palit GTX 260 SONIC 216SP - Core 2 Duo E8400 with Xigmatek HDT-S1283 cooler - 850watt Antec True Power Quattro -
Old February 26, 2009, 11:06 AM
3oh6's Avatar
Hardware Canucks Reviewer
yeah, you have to state whether PhysX is enabled or disabled to even compare. the OP has PhysX disabled.
and perhaps Vista VS XP...biiiiig difference in 06
Old February 26, 2009, 12:06 PM
Jake_HT's Avatar
I have physx enabled and am using XP yes.
Old February 26, 2009, 12:13 PM
3oh6's Avatar
then that explains your almost equal score with less GPU power. run without PhysX in Vista and the gap will equal out
I disabled PPU in the options menu before the run and my OS is Vista 64 bit.
Just for grins I ran vantage, with ppu enabled, and got 27835; not legit but interesting none the less.
When I filtered the vantage benchmark scores to reflect i7, GTX285, Vista 64 and only official results, my score is 7th from the top but that's at 3.8GHz. If I play with my bios I can get it up to just over 4GHz, which should raise my ranking a couple of places.
BTW, to the best of my knowledge no one above my ranking is only on air cooling.
Mountain Mods Watercooling on GTX285 SLI + i7 Toronto122 Case Mods, Worklog & Gallery 17 March 25, 2009 05:31 PM
PSU to run a GTX285 and 9800 GX2?? CasheKicker Power Supplies 5 February 25, 2009 06:44 AM
My new GTX285 OC CasheKicker Video Cards 5 February 19, 2009 05:08 PM
EVGA Releases GTX285 FTW Edition Eagle Eye Press Releases & Tech News 6 January 30, 2009 03:56 PM
EVGA Geforce GTX285 officially announced Eagle Eye Press Releases & Tech News 13 January 10, 2009 09:20 PM
