Old February 24, 2009, 10:41 PM
dadzilla's Avatar
Default 9800gtx+ oddness. Input requested
This just started happening randomly in the last couple of weeks. Every now and then, I completely lose video right in the middle of a session. I could be running for an hour, or maybe two, or only ten minutes. The monitor actually flashes the power light as if it had been left on when the computer shut down. I tried deleting drivers and putting in a new set, but no luck - it still happens once in a while - like every third day or so. Weird though, I can play FarCry2 for three hours straight and no trouble. Then next time I'm on, I lose video with only a browser open? Driver version is 7.15.0011.8122.
I build, I game, I upgrade. I build, I game, I upgrade. I build.....
Old February 24, 2009, 10:49 PM
Phobia's Avatar
I had a similar problem with my 9800gx2. I ended up using compressed air and blowing as much of the dust buildup out of it as possible. It seemed to work, as the card didn't do that afterwards.
Old February 24, 2009, 11:20 PM
dadzilla's Avatar
OK- worth a try for sure. I'll have to run out and get a can of air in the AM.
Old February 25, 2009, 08:25 AM
norfolk's Avatar
Hey Dadzilla.Your card is doing the exact same thing my first BFG 9800 GTX OCx.I"m on my second card thx to there awesome RMA process.
Old February 25, 2009, 09:23 AM
element291's Avatar
I found that only starting yesterday my screen would get like a thousand tiny black squares, and everything would freeze until i did a hard restart. I installed the acellero xtreme and its being cooled 10 times more than the stock cooler..... i don't know what could cause that...
| ASUS P8Z68-VPRO | Intel i5 2500K | 8Gb Patriot Viper Xtreme | 2x 60gb OCZ Solid 3 SSD | EVGA GTX260 Core216 |
Old February 25, 2009, 09:28 AM
dadzilla's Avatar
element291 - when I googled this last night I kept coming up with threads about your problem - seems to be fairly common? Mine is different in that all video just stops. I'm going to try the air clean and then if I have to I will RMA to XFX. Then we will find out how good they are. Do you send it back to NCIX or right to XFX< anybody know?
Old February 25, 2009, 09:31 AM
element291's Avatar
When did you buy it. Probably XFX.
What did you find about my problem ;) hehehe
thenewguy001's Avatar
It's an epidemic problem with all nvidia 9 series cards, that shuts themselves off all of a sudden. It's a problem with the overvoltage protection circuit, so it's a hardware, not driver problem. There are huge threads about it on the evga and nvidia forums. just do a search for black screen of death for 9600 and 9800gt cards on google.
examples:
9600gt black screen sound loop - Google Search
RE: 9600GT SSC Edition Black Screen Crashes
NVIDIA Forums > 9600GT Black Screen of Death!
i5 2500K @ 4.0 GHz
2 x 4GB G.Skill Ripjaws X
Patriot Pyro 240GB
Gigabyte HD 6970 OC
Gigabyte Z68X-UDH3-B3
Seasonic 760W
Coolermaster Hyper 212+
CM690 w/ 1-80mm, 6-120mm fans.
Old February 25, 2009, 10:30 AM
dadzilla's Avatar
Yes there is a lot of ideas on this out there and a lot of fellows have the same two problems: either the black screen of death (my problem) or the weird checkerboard problem. Sigh. I just want it to work properly - could care less about getting the last 3% of performance out of it.
Old February 25, 2009, 10:49 AM
underclock your card and problems should go away. However, you won't be getting all the performance you are entitled to. I've underclocked my card from 675 MHz to 608 MHz and the problems went away completely. I can RMA it but I don't have a back up card and I can't go 2+ weeks without a vid card. With these problems and XFX making ATI cards now, this will be the last Nvidia card I'm buying, to me honest.
i5 2500K @ 4.0 GHz
Patriot Pyro 240GB
Gigabyte HD 6970 OC
Seasonic 760W
Input guys shayan288 Gaming 6 November 9, 2008 10:17 PM
My WC system to be expanded...critique requested RussianRedScorpion Water Cooling 19 April 28, 2008 09:30 AM
Input Lag from Monitor Computergeek Troubleshooting 6 April 5, 2008 11:09 AM
need input flybye Overclocking, Tweaking and Benchmarking 4 September 11, 2007 02:34 PM
advice requested on new monitor rob123 Display Units 10 June 2, 2007 06:57 PM
